首页 > 国外线缆
[问题求助] 请帮忙最新的UL2733标准
P:2010-11-09 17:39:05
请ul2733  ul 2463 ul2464标准,请高手帮忙。
transmission handwidth - 传输带宽,传输频带宽度 (0) 投诉
P:2010-11-10 08:54:35
有需要的可以看看
UNDERWRITERS LABORATORIES APPLIANCE WIRING MATERIAL
Subj.758 Section 2 Page 2733 Issued:1975-06-23
Revised:2008-05-27
Style 2733 Jacketed Cord.
Rating 105 deg C, 600 Vac, Horizontal flame.
Insulation Labeled style 1015
Assembly Two to seven conductors cabled together. Length of lay not specified. Fillers optional. Maximum diameter of cable assembly under jacket is .350 inches.
Jacket PVC, 15 mils min average, 12 mils minimum at any point.
Standard Appliance Wiring Material UL 758.
Marking General.
Use Internal wiring of electric fans.
viscosimeter - 粘度计 (0) 投诉
P:2010-11-10 09:09:31
有需要的可以看看
triple clad fiber - 三包层光纤 (0) 投诉
P:2010-12-14 18:19:01
正好需要,谢谢
IWG - Imperial Standard Wire Gauge皇家标准线规(英国) (0) 投诉
P:2011-05-11 11:51:47
正好需要
epoxy enamelled wire - 环氧漆包线 (0) 投诉
P:2011-05-13 13:38:50
正好需要
repulse ring - 推线环(收、放线装置或牵引轮的) (0) 投诉
P:2013-01-15 08:57:36
又是點數不夠了,先留言等會下載
digital multi-programme system - 数字多程序系统 (0) 投诉
P:2015-12-22 12:30:02
有没有整套style page?
motor-driven roller for cable laying - 电动机驱动的电缆敷设滑轮 (0) 投诉
P:2023-09-12 13:36:51
http://www.dxdlw.com/ShowPost.aspx?pid=1879157
on-line process control - 在线过程控制 (0) 投诉
