首页 > 国外线缆
[问题求助] UL94 塑料的燃烧级别-- V-0等级最高吗?
P:2007-04-07 14:33:37
UL94 塑料的燃烧级别
Test for Flammability of Plastic Materials for Parts in Devices and Appliances
TESTS
7 Horizontal Burning Test; HB
(ASTM D 635, D 4804, IEC 707, or ISO 1210)
7.1 Test criteria
7.1.1 A material shall be classified HB when tested as described in 7.2.1 – 7.5.10.
7.1.2 A material classed HB shall (also see 7.1.4):
a) Not have a burning rate exceeding 40 mm per minute over a 75 mm span for specimens having a thickness of 3.0 – 13 mm, or
b) Not have a burning rate exceeding 75 mm per minute over a 75 mm for specimens having a thickness less than 3.0 mm, or
c) Cease to burn before the 100 mm reference mark. See 7.5.1 and 7.5.9.
*7.1.2 revised July 29, 1997*
7.1.3 A material classified HB in the 3.0 +0.2 mm thickness shall automatically be classed HB down to a 1.5
mm minimum thickness without additional testing. *7.1.3 revised July 29, 1997*
7.1.4 If only one specimen from a set of three specimens does not comply with the requirements, another set of three specimens is to be tested. All specimens from this second set shall comply with the requirements in order for the material in that thickness to be classified HB.
*7.1.4 revised July 29, 1997*
7.2 Test apparatus
7.2.1 See 5.1, 5.2, 5.5 – 5.12, 5.20 and 5.21.
7.3 Test specimens
7.3.1 All specimens shall be cut from sheet material, or shall be cast or injection, compression transfer or pultrusion molded to the necessary form. After any cutting operation, care is to be taken to remove all dust and any particles from the surface; cut edges are to have a smooth finish. Fabrication of test specimens shall be in accordance with current ASTM Practices.
7.3.2 Standard bar specimens are to be 125 ±5 mm long by 13.0 ±0.5 mm wide, and provided in the minimum thickness and 3.0 (-0.0 +0.2) mm thick. The 3.0 mm thick specimens are not necessary if the minimum thickness is greater than 3.0 mm, or the maximum thickness is less than 3.0 mm. The maximum thickness is not to exceed 13 mm. The maximum width is not to exceed 13.5 mm, the edges are to be smooth, and the radius on the corners is not to exceed 1.3 mm.
7.3.3 Material Ranges – If a material is to be considered in a range of colors, densities, melt flows, or reinforcement, specimens representing these ranges are also to be provided.
7.3.4 Specimens in the natural and in the most heavily pigmented light and dark colors are to be provided and considered representative of the color range, if the test results are essentially the same. In addition, a set of specimens is to be provided in the heaviest organic pigment loading, unless the most heavily pigmented light and dark colors include the highest organic pigment level. When certain color pigments (for example, red, yellow, or the like) are known to affect flammability characteristics, they are also to be provided.
7.3.4 revised June 10, 1997
7.3.5 Specimens in the extremes of the densities, melt flows and reinforcement contents are to be provided and considered representative of the range, if the test results are essentially the same. If the burning characteristics are not essentially the same for all specimens representing the range, evaluation is to be limited only to the materials in the densities, melt flows, and reinforcement contents tested, or additional specimens in intermediate densities, melt flows, and reinforcement contents are to be provided for tests.
7.4 Conditioning
7.4.1 Two sets of three specimens are to be preconditioned as in 6.1.
7.5 Procedure
7.5.1 Three specimens are to be tested. Each specimen is to be marked with two lines perpendicular to the longitudinal axis of the bar, 25 ±1 mm and 100 ±1 mm from the end that is to be ignited.
7.5.1 revised April 30, 1997
7.5.2 Clamp the specimen at the end farthest from the 25 mm mark, with its longitudinal axis horizontal and its transverse axis inclined at 45 ±2 degrees. The wire gauze is to be clamped horizontally beneath the specimen, with a distance of 10 ±1 mm between the lowest edge of the specimen and the gauze with the free end of the specimen even with the edge of the gauze. See Figure 7.1.
7.5.2 revised April 30, 1997
7.5.3 The methane gas supply to the burner shall be arranged as in Figure 7.3 and adjusted to produce a gas flow rate of 105 ml/min with a back pressure less than 10 mm water. See ASTM D 5207.
7.5.4 The burner is to be placed remote from the specimen and ignited. Adjust the burner to produce a blue flame 20 ±1 mm high. The flame is to be obtained by adjusting the gas supply and the air ports of the burner until an approximate 20 ±1 mm yellow-tipped blue flame is produced. Increase the air supply until the yellow tip disappears. Measure the height of the flame again and adjust it if necessary.
7.5.5 The test flame shall be calibrated in accordance with ASTM D 5207 at least once a month and when the
gas supply is changed, test equipment is replaced, or when data is questioned. *7.5.5 revised July 10, 1998*
7.5.6 If the specimen sags at its free end during the initial set up, the support fixture illustrated in Figure 7.2 is to be positioned under the specimen with the small extending portion of the support fixture at least 20 mm from the free end of the specimen. Enough clearance is to be provided at the clamped end of the specimen so that the support fixture is capable of being freely moved sidewards. As the combustion front progresses along the specimen, the support fixture is to be withdrawn at the same approximate rate.
7.5.6 revised June 10, 1997
7.5.7 Apply the flame to the free end at the lower edge of the specimen. The central axis of the burner tube is to be in the same vertical plane as the longitudinal bottom edge of the specimen and inclined toward the end of the specimen at an angle of approximately 45 degrees to the horizontal. See Figure 7.1.
7.5.8 Position the burner so that the flame impinges on the free end of the specimen to a depth of 6 ±1 mm. Apply the test flame for 30 ±1 seconds without changing its position; remove the burner after 30 ±1 seconds, or as soon as the combustion front of the specimen reaches the 25 mm mark (if less than 30 seconds). Start the timing device when the combustion front reaches the 25 mm mark.
7.5.9 If the specimen continues to burn after removal of the test flame, record the time in seconds, for the combustion front to travel from the 25 mm mark up to the 100 mm mark and record the damaged length, L. If the combustion front passes the 25 mm mark but does not pass the 100 mm mark, record the elapsed time in seconds and the damaged length, L, in millimeters between the 25 mm mark and where the combustion front stops.
7.5.10 The test procedure is to be conducted on at least three specimens.
7.6 Calculations
7.6.1 Calculate the linear burning rate, V, in millimeters per minute, for each specimen using the equation: V = 60 L/t
in which: V is the linear burning rate in mm/minute L is the damaged length, in millimeters t is time, in seconds
Note: If the flame front passed the 100 mm mark, L = 75 mm.
7.7 Results
7.7.1 The following are to be recorded for each specimen: a) Whether or not the flame front passed the 25 mm and 100 mm marks. b) If the flame front passed the 25 mm mark but ceased before the 100 mm mark, the damaged
length, L and elapsed time, t.
c) If the flame front passed the 100 mm mark, the elapsed time t between the 25 mm and 100 mmmarks.d) The calculated linear burning rate.
Figure 7.1
Horizontal burning test for HB classification
Figure 7.2
Flexible specimen support fixture
8 20 mm Vertical Burning Test; V-0, V-1, or V-2
(ASTM D 3801, IEC 707, or ISO 1210)
8.1 Test Criteria
8.1.1 Materials shall be classified V-0, V-1, or V-2 on the basis of results obtained on small bar specimens
when tested as described in (8.2.1 – 8.5.6). *8.1.1 revised July 29, 1997*
8.1.2 Some materials, due to their thinness, distort, shrink, or are consumed up to the holding clamp when subjected to this test. These materials may be tested in accordance with the test procedure in Thin Material Burning Test; VTM-0, VTM-1, VTM-2... Section 11, provided specimens can be properly formed.
*8.1.2 revised July 29, 1997*
8.1.3 Table 8.1 specifies the material classifications.
Table 8.1
Materials classifications
Criteria conditions
V-0
V-1
V-2
Afterflame time for each individual specimen t or t1 2 Total afterflame time for any condition set (t plus t for the 5 specimens)1 2 Afterflame plus afterglow time for each individual specimen after the second flame application (t +t )2 3 Afterflame or afterglow of any specimen up to the holding clamp Cotton indicator ignited by flaming particles or drops
#10s #50s #30s No No
#30s #250s #60s No No
#30s #250s #60s No Yes
*Table 8.1 revised July 29, 1997*
8.1.4 If only one specimen from a set of five specimens does not comply with the requirements, another set of five specimens is to be tested. In the case of the total number of seconds of flaming, an additional set of five specimens is to be tested if the totals are in the range of 51 – 55 seconds for V-0 and 251 – 255 seconds for V-1 and V-2. All specimens from this second set shall comply with the appropriate requirements in order for the material in that thickness to be classified V-0, V-1, or V-2.
*8.1.4 revised July 29, 1997*
8.1.5 Type 66 nylon materials classed V-2 shall have a relative viscosity (RV) of less than 120 in the supplied form, as determined by the method specified in 8.1.6, or if the relative viscosity is 120 or greater, the relative viscosity of the molded specimen shall not be less than 70 percent of the relative viscosity in the supplied form. *8.1.5 revised July 29, 1997*
8.1.6 The relative viscosity is to be determined by the solution method in ASTM D789, using either a pipet or Brookfield viscometer.
8.2 Test apparatus
8.2.1 See 5.1, 5.2, 5.5 – 5.8, 5.10, 5.12 – 5.15, 5.20 and 5.21.
8.3 Test specimens
8.3.1 All specimens are to be cut from sheet material, or are to be cast or injection, compression, transfer or pultrusion molded to the necessary form. After any cutting operation, care is to be taken to remove all dust and any particles from the surface; cut edges are to have a smooth finish. Fabrication of test specimens shall be in accordance with current ASTM Practices.
8.6 Results
8.6.1 The following are to be observed and recorded:
a) Afterflame time after first flame application, t .
b) Afterflame time after second flame application, t .
c) Afterglow time after second flame application, t .
d) Whether or not specimens burn up to the holding clamp.
e) Whether or not specimens drip flaming particles that ignited the cotton indicator.
*Figure 8.1 title revised July 29, 1997*
ragging - 刻纹,刻槽<轧辊表面缺陷>;划伤,刮痕;凹凸不平的,粗糙的 (0) 投诉
P:2007-04-27 11:53:30
大家一起交流交流吗
bearer - 支架,支座,托架;载体 (0) 投诉
P:2007-05-03 13:38:47
测试对于塑料材料的燃烧性为部份在设备和器具 测试 7 水平的灼烧的测试; HB (ASTM D 635, D 4804, IEC 707, 或ISO 1210) 7.1 测试标准 7.1.1 材料将是被分类的HB 何时测试如所描述在7.2.1 - 7.5.10 。 7.1.2 材料分类的HB 将(也看见7.1.4): a) 没有灼烧的率超出40 毫米每分钟在一个75 毫米间距为标本有3.0 - 13 毫米的厚度, 或 b) 没有灼烧的率超出75 毫米每分钟在一75 毫米为标本有厚度少于3.0 毫米, 或 c) 停止烧在100 毫米参考标记之前。看见7.5.1 和7.5.9 。 * 7.1.2 校正了1997 年7月29 日
* 7.1.3 材料被分类的HB 在3.0 +0.2 毫米厚度自动地将是分类的HB 下来到1.5 毫米极小的厚度没有另外测试。* 7.1.3 被校正1997 年7月29 日
* 7.1.4 如果只一个标本从一套三个标本不依从要求, 其它套三个标本将被测试。所有标本从这个第二个集合将依从要求为了材料在那种厚度是被分类的HB 。
* 7.1.4 校正了1997 年7月29 日* 7.2 测试用具 7.2.1 看见5.1, 5.2, 5.5 - 5.12, 5.20 和5.21 。
7.3 测试标本
7.3.1 所有标本将被削减从板料材料, 或将被熔铸或射入、压缩调动或pultrusion 将被铸造对必要的形式。在任一切口操作以后, 关心将被采取从表面去除所有尘土和所有微粒; 裁减边缘将有光滑的结束。测试标本的制造将是与当前的ASTM 实践符合。 7.3.2 标准酒吧标本将是125 .5 毫米长由13.0 .0.5 毫米宽, 和假设在极小的厚度和3.0 (-0.0 +0.2) 毫米浓厚。3.0 毫米厚实的标本不是必要的如果极小的厚度是大于3.0 毫米, 或最大厚度是少于3.0 毫米。最大厚度不将超出13 毫米。最大宽度不将超出13.5 毫米, 边缘将是光滑的, 并且半径在角落不将超出1.3 毫米。
7.3.3 物质范围- 如果材料将被考虑在颜色、密度、融解流程, 或增强的范围, 标本代表这些范围并且将被提供。 7.3.4 标本在自然和在沉重被着色的轻和暗色将被提供并且颜色的被考虑的代表排列, 如果测试结果根本上是相同。另外, 一套标本将被提供在最重的有机颜料装货, 除非沉重被着色的轻和暗色包括最高的有机颜料水平。当某些颜色颜料(例如, 红色、黄色, 或类似物) 知道影响燃烧性特征, 他们并且将被提供。 7.3.4 被校正1997 年6月10 日 7.3.5 标本非常密度、融解流程和增强内容的将被提供和范围的被考虑的代表, 如果测试结果根本上是相同。如果灼烧的特征根本上不是同样为所有标本代表范围, 评估将只对材料被限制在密度, 融解流动, 和增强内容被测试, 或另外的标本在中间密度、融解流程, 和增强内容将为测试被提供。
7.4 适应
7.4.1 二套三个标本将被预先处理和在6.1 。 7.5 做法
7.5.1 三个标本将被测试。各个标本将被标记用二条线垂直对酒吧、25 .1 毫米和100 .1 毫米的纵向轴从将被点燃的末端。
7.5.1 被校正1997 年4月30 日
7.5.2 夹紧标本在末端远从25 毫米标记, 用它的纵向轴水平和它的横向轴倾斜在45 .2 度。导线纱将被夹紧水平地在标本之下, 以距离10.1 毫米在标本的最低的边缘和纱之间与标本的自由末端以纱的边缘。参见图7.1 。
7.5.2 被校正1997 年4月30 日
7.5.3 对燃烧器的甲烷气供应将被安排和在表7.3 和将被调整导致105 ml/min 的气体流速以反压力少于10 毫米水。参见ASTM D 5207 。
7.5.4 燃烧器将是被安置的遥控从标本和点燃。调整燃烧器生产蓝色火焰20 .1 毫米高。火焰将由调整获得供气和燃烧器的空气口岸直到近似20 .1 毫米黄色被打翻的蓝色火焰被生产。增加供气直到黄色要诀消失。再测量火焰的高度和调整它如果需要。
7.5.5 测试火焰将被校准与ASTM D 5207 符合至少每月一次和何时 供气被改变, 试测器材被替换, 或当数据对表示怀疑。
* 7.5.5 校正了1998 年7月10 日
* 7.5.6 如果标本下垂在它的自由末端在最初期间被设置, 支持装置被说明在表7.2 将被安置在标本之下以支持装置的小延伸的部份在最少20 毫米从标本的自由末端。足够的清除将被提供在标本的被夹紧的末端以便支持装置是能向侧面地自由地被移动。作为燃烧前线进步沿标本, 支持装置将被撤出以同样近似率。
7.5.6 被校正1997 年6月10 日
7.5.7 向自由末端应用火焰在标本的更低的边缘。燃烧器管的中央轴和标本的纵向下缘一样将是在垂直平面和倾斜往标本的末端有一个角度大约45 度对水平。参见图7.1 。
7.5.8 安置燃烧器以便火焰冲击在标本的自由末端对6 .1 的深度毫米应用测试火焰30 .1 秒钟没有改变它的立场; 去除燃烧器在30 .1 以后秒钟, 或当标本的燃烧前线到达25 毫米标记(如果少于30 秒) 。发动时间设备当燃烧前线到达25 毫米标记。
7.5.9 如果标本继续烧在测试火焰的撤除以后, 记录时候在几秒钟内, 为了燃烧前线旅行从25 毫米标记由100 毫米标记决定和记录损坏的长度, L 。如果燃烧前线通过25 毫米标记但不通过100 毫米标记, 记录流逝的时间在秒钟和损坏的长度, L, 在毫米在25 毫米标记之间和燃烧前线停止的地方。
7.5.10 试验过程将被举办在至少三个标本。
7.6 演算
7.6.1 计算线性灼烧的率, V, 在毫米每分钟, 为各个标本使用等式: V = 60 L/t 在哪些: v 是线性灼烧的率在mm/minute L 是损坏的长度, 在t 是时间的毫米, 在几秒钟内 注: 如果火焰前线通过了100 毫米标记, L = 75 毫米。
7.7 结果 7.7.1 下列将被记录为各个标本:
a) 是否火焰前线通过了25 毫米和100 个毫米标记。
b) 如果火焰前线通过了25 毫米标记但停止了在100 毫米标记之前, 被损坏 长度、L 和流逝的时间, t 。
c) 如果火焰前线通过了100 毫米标记, 流逝的时间t 在25 毫米和100 mmmarks.d 之间) 故意的线性灼烧的率。 图7.1 水平的灼烧的测试为HB 分类图7.2 灵活的标本支持装置 8 20 毫米垂直的灼烧的测试; V-0 、V-1, 或V-2 (ASTM D 3801, IEC 707, 或ISO 1210)
8.1 测试标准
8.1.1 材料将是被分类的V-0 、V-1, 或V-2 根据结果被获得在小酒吧标本 当测试如所描述(8.2.1 - 8.5.6) 。
* 8.1.1 被校正1997 年7月29 日
* 8.1.2 一些材料, 由于他们的薄, 变形, 收缩, 或被消耗由藏品钳位决定当服从对这个测试。这些材料也许被测试与试验过程符合在稀薄的物质灼烧的测试; VTM-0, VTM-1, VTM-2... 部分11, 假设标本可能适当地被形成。
* 8.1.2 被校正1997 年7月29 日* 8.1.3 表8.1 指定物质分类。 表8.1 材料分类 标准条件 V-0 V-1 V-2 Afterflame 时间为各单独标本t 或t1 2 总afterflame 时间为任一个情况设置了(t 加上t 为5 specimens)1 2 Afterflame 加上残光时间为各个单独标本在第二种火焰应用以后(t +t)2 3 Afterflame 或残光任一个标本由藏品钳位棉花显示决定点燃了由火焰状微粒或下落 #10s #50s #30s 没有没有 #30s #250s #60s 没有没有 #30s #250s #60s 没有是 * 表8.1 被校正1997 年7月29 日* 8
翻译网页
outlet wire diameter - 出线直径,成品线直径 (0) 投诉
P:2007-05-11 17:08:26
我是问哪一个要求高,请大侠帮忙
colour cord - 彩色软线 (0) 投诉
