首页 > 国外线缆
[问题求助] UL STYLE PAGE 1731寻求
P:2010-11-03 19:58:30
各位 :
是否有UL1731 STYLE PAGE?
提供一下;
謝謝!!!
note-type personal computer - 记录式个人计算机,笔记本式个人电脑 (0) 投诉
P:2010-11-03 22:01:19
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 1 Page 1731 Issued: Sept. 13, 1977
Revised: April 13, 2001
Style 1731 Extruded PVC Insulated Wire.
______________________________________________________________________________
Rating 105°C, 300 V.
*Conductor Nos. 50-16 AWG, solid or stranded, tinned or bare copper,
Sec. 5.
Insulation Extruded PVC; 9 mil min average, 7 mil min at any point.
Covering (Optional) Extruded 33 Nylon in 2 mil min thickness or
Lacquered Braid.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, unaged, Class 43.
*Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties, Class 43.
Program (4) Heat Shock.
(4) Cold Bend.
(4) Horizontal Flame Test.
(4) Deformation.
Marking General.
Use For further processing in Cables for Electronic Equipment or
Appliances.
tension controlled pay-off stand - 张力控制放线架 (0) 投诉
P:2010-11-04 08:52:14
学习了
triplex cable - triple cable (0) 投诉
P:2013-06-19 10:48:12
楼主你可以去UL网站上down,只要是有的,都能找到。
duplex cord - 双芯软线,双芯软绳 (0) 投诉
