[问题求助] 这段同轴电缆什么意思啊 英文
P:2010-10-12 08:13:07
1) TV WIRE-1/48 :Coaxial cable RG 6, CCS, COO, Inner conductor - 0.80mm, Branding - 0.12mm ( countable wire 48pcs wire), Foamsed PE Dielectric 4.5 PVC Jacket ( Black ) Outer 6.35mm, 48 wire, 0.12mm, 100 yrd/Roll, 6Roll/Carton.
2) TV WIRE-3/80 : Coaxial cable RG 6, CCS, COO, INNER CONDUCTOR - 1.02MM, BRANDING : 0.12MM ( COUNTABLE WIRE 96PCS WIRE ) FOAMED PE DIELECTRIC : 4.75 PVC JACKET ( BLACK ) OUTER - 6.85MM, 96 WIRE, 0.12MM. 100YRD/ ROLL OR 300 YRD / ROLL,
OTHERS INSTRUCTION :
insulated ( including enamelled or anodised ) wire cable ( including co-axial cable ) and other insulated electric conductors, whether or not fitted with connectors, optical fibre cablrs, made up of individually sheathed fibres, whether or not assembled with electric conductors or fitted with connectors coaxial cable and other co-axial electric conductors.
ceramic liner - 瓷套管,陶瓷衬层 (0) 投诉
P:2010-10-12 10:41:30
1. 導體0.8 ccs , 絕緣發泡PE , 外徑4.5mm, 編織48/0.12mm 護套外徑6.35mm, 100碼/轆, 6轆/箱
2. 導體1.02 ccs , 絕緣發泡PE , 外徑4.75mm, 編織96/0.12mm 護套外徑6.35mm, 100碼/轆 或300碼/轆
bend testing machine - 弯曲试验机 (0) 投诉
P:2010-10-12 10:44:33
1. 导体0.8 ccs , 绝缘发泡PE , 外径4.5mm, 编织48/0.12mm 护套外径6.35mm, 100码/轆, 6轆/箱
2. 导体1.02 ccs , 绝缘发泡PE , 外径4.75mm, 编织96/0.12mm 护套外径6.85mm, 100码/轆 或300码/轆
distributed fiber-optic sensor - 分布式光纤传感器 (0) 投诉
P:2010-10-12 11:04:22
谢谢 你QQ多少 我的365101735
triple joint - 三头连接;电缆分支套管 (0) 投诉
P:2010-10-12 11:05:13
能帮忙看下编织材料和外套厚度吗
ringmarker - 环形标志器,环形印字机 (0) 投诉
P:2010-10-12 11:44:40
編織材料沒有顯示, 一般內導體ccs會用鋁鎂絲, 外護套厚度按外徑計算就可以了
laminar insulation - 层状绝缘,多层绝缘,多层粘接绝缘 (0) 投诉
