首页 > 汽车线缆
[汽车电线] 急求1007 22AWG系列标准
P:2010-10-08 11:25:42
你是不是要UL1007 的规范啊。
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 1007 Issued:
Revised:
Style 1007 Polyvinyl Chloride Insulated Wire.
______________________________________________________________________________
Rating
Conductor 32-16 AWG, solid or stranded.
Insulation Polyvinyl Chloride, 15 mils minimum average,
13 mils minimum at any point, 60 or
if applicable.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, Unaged.
Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties.
Program (4) Heat Shock.
(4) Cold Bend
* (4) Deformation.
* (12) Horizontal Flame Test.
Marking General.
Use Internal wiring of appliances; or where exposed to oil
at a temperature not exceeding
is applicable. Tags may indicate the following:
600 V Peak - For Electronic Use Only.
CW - Copper Weld wire铜包钢 (0) 投诉
P:2010-10-08 11:33:01
导体 | 绝缘 | 最大导体电阻 (Ω/km, | 耐压强度 (VAC,1min) | |||
规格AWG | 构造(No./mm) | 外径 (mm) | 厚度(mm) | 外径 (mm) | ||
30 | 7/0.10 | 0.30 | 0.40 | 1.10 | 381 | 2,000 |
28 | 1/0.32 7/0.127 | 0.32 0.38 | 0.39 0.41 | 1.10 1.20 | 227 239 | 2,000 |
26 | 1/0.404 7/0.16 | 0.40 0.48 | 0.43 0.41 | 1.25 1.30 | 143 150 | 2,000 |
24 | 1/0.511 11/0.16 | 0.51 0.61 | 0.42 0.40 | 1.35 1.40 | 89.3 94.2 | 2,000 |
22 | 1/0.643 17/0.16 | 0.64 0.76 | 0.43 0.42 | 1.50 1.60 | 56.4 59.4 | 2,000 |
20 | 1/0.813 21/0.178 | 0.81 0.94 | 0.42 0.43 | 1.65 1.80 | 35.2 36.7 | 2,000 |
18 | 1/1.024 16/0.254 34/0.178 | 1.02 1.17 1.20 | 0.41 0.47 0.45 | 1.85 2.10 2.10 | 22.2 23.2 23.2 | 2,000 |
16 | 1/1.29 26/0.254 | 1.29 1.49 | 0.46 0.46 | 2.20 2.40 | 14.0 14.6 | 2,000 |
open-cast mining cable - 露天矿用电缆 (0) 投诉
