首页 > 国外线缆
[技术资料] 部分UL线材生产参数
P:2010-09-15 15:26:21
补充一下
| UL 1007 HOOK-UP WIRE 连接线 |
| ●额定温度:80℃ ●额定电压:300V ●参考标准:UL758,UL1581,CSA C22.2No.210.2 ●导体使用单支或绞合32~16AWG镀锡或裸铜 ●PVC绝缘,符合ROHS环保标准 ●通过UL VW-1、CSA FT1及JQA F-Mark阻燃测试 ●绝缘厚度均匀、易裁线、易剥皮 ●用于一般电子、电器设备内部连接线 | ●Rated temperature:80℃ ●Rated voltage:300V ●Reference standard:UL758,UL1581,CSA C22.2No.210.2 ●Solid or stranded ,tinned or bare copper conductor 32~16AWG ●PVC insulation ,comply with ROHS environmental standard ●Passes UL VW-1,CSA FT1 and JQA F-Mark flame test ●Uniform insulation thickness to ensure easy stripping and cutting ●For general purpose internal wiring of appliance |
oz-ounce - 盎司(等于28.35g) (0) 投诉
22
