首页 > 矿用橡套电缆
[矿用电缆] 我们厂的矿用电缆介绍
P:2010-09-15 11:51:09
矿用橡套软电缆
发布:2008-4-23 16:10:31           点击: ( 1723 )
Flexible rubber-sheathed cables for mining purposes
产品标准standard
本产品按GB12972-1991《矿用橡套软电缆》、MT818-1999《煤矿用阻燃电缆》及Q/320282DCE037-2003标准生产,同时还可根据用户需要按国际电工委员会推荐标准IEC、英国标准、德国标准及美国标准生产。
The product is manufactured according to the standard 《Flexible rubber-sheathed cables for mining purposes》of GB12972-1991,《Flame retardant drade flexible rubber-sheathed cables for mining purposes》of MT818-1999, and Q/320282DCE037-2003, and the same time is also manufactured according to the standard of IEC、English、Germany and America.
适用范围Applications
矿用橡套软电缆适用于工频额定电压U0/U660/1140V及以下矿用动力装置用移动敷设的电缆。
Flexible rubber-sheathed cables for mining purposes of suitable for mining purposes power device with moving installation and rated voltage up to and including 660/1140V.
使用特性Operating characteristics
● 工频额定电压U0/U为380/660V、660/1140V。
Rated power-frequency voltage U0/U:380/660V and 660/1140V。
● 电缆导体的最高允许工作温度:65℃
Max. admissible operating temperature of the conductor:65℃
● 电缆允许最低的工作环境温度为-35℃
Permissible long-term operating temperature: Lowest working temperature is :-35℃
● 电缆弯曲半径:The bending radius of cable
D≤25mm.: ≥4D
D>25mm.: ≥6D
(D—Diameter of the cable).
型号.名称Type and Designation
型号 Type名称 Designation
U
UY
MY
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用移动橡套软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible cables forming purposes.
UP
UY
P MYP
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用屏蔽移动橡套软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible shielding cables forming purposes.
UC
MC
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套采煤机软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible coal cutter cables forming purposes.
UCP
MCP
UCPQ
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套采煤屏蔽软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible coal cutter shielding cables forming purposes.
UZ
UZP
MZ
MZP
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用电钻电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible drill cables forming purposes.
UYQ
MYQ
天然丁苯橡皮绝缘(阻燃)氯丁橡皮护套矿用轻型软电缆 NR/SBR rubber insulated Flame retardant grade neoprene(CR) rubber sheathed flexible light-duty cables forming purposes.
生产范围 Production range of cable
型号 Type额定电压 Rated voltages V芯数 NO.of cores标称截面 Nominal cross-sectional area mm2
主线 Principal line地线 Ground wire控制线 Controlled line
U*10003112.5~70
UP*10003112.5~70
UY ●
MY
380/66031—4~70
UYP ●
MYP
380/66031—4~70
UYP ●
MYP
660/114031—4~70
UC*1000312~710~50
UC ●
MC
380/660313~716~50
UCP*1000312~710~50
UCP ●
MCP
380/660313~716~50
UCPQ*114031335~70
UCP ●
MCP
660/114031335~95
UZ ●
UZP ●
MZ MZP
300/5003112.5~4
UYQ ●
MYQ
300/5002~12——1.0~2.5
注:“●”的产品按GB12792-1991标准生产。
“*”的产品按Q/320282DCE037-2003标准生产。
其余产品按MT818-1999标准生产。
Note: “●”indicates that the product is manufactured according to the standard of GB12972-1991
“*”indicates that the product is manufactured according to the standard of Q/320282DCE037-2003.
The rest product is manufactured according to the standard of MT818-1999.
结构尺寸及主要技术参数Construction and main technical data
● 矿用移动橡套软电缆
型号(Type):U 额定电压(Rating Voltage):1000V
备注:
1、电缆绝缘主线芯之间及主线芯与地线之间的绝缘电阻,换算到+20℃时不低于100MΩ·km。
2、产品标准:Q/320282DCE037-2003。
3、U型电缆有4芯和5芯两种结构,有3根主线芯和一根地线芯组成(5芯电缆中有一芯为控制线),围绕垫芯绞合成缆,外面挤包氯化聚乙烯橡皮护套或黑色氯丁橡皮护套。
4、导电线芯:采用软铜线,其性能符合 GB/T3956-1997。
5、绝缘:采用GB7594.2-1987中XJ-00A型橡皮。
6、线芯识别:采用绝缘分色识别,主线芯红、绿、白。地线黑色,控制线白色。
7、成缆:主线芯、地线、控制线围绕橡皮垫芯按右向绞合成缆。
8、护套:采用GB7594.7-1987中XH-03A型橡皮。
9、普通型U型成品电缆具有不延燃性能,阻燃型U型成品电缆的阻燃性能满足MT386-1995的要求。
10、电缆标志:电缆表面印有型号、电压、规格及制造厂名称。
● 矿用移动橡套软电缆
型号(Type):MY 额定电压(Rating Voltage):380/660V
芯数截面 Nom.cross sectional areas mm2导体结构 Conductor structure NO./mm绝缘厚度 Insulation thickness mm护套厚度 Sheath thickness mm电缆外径 Average diameter参考重量 Cable approx. weight kg/km导体(铜)最大直流电阻 Max.D.C. resistance(20 ℃ ) Ω /km20 ℃载流量 Current carring capacity(20 ℃ ) A
标称 Normianal mm最大 Max mm
3 × 4+1 × 456/0.301.43.520.923.06374.95035
56/0.304.950
3 × 6+1 × 684/0.301.43.522.925.18563.30046
84/0.303.300
3 × 10+1 × 1084/0.401.64.027.830.613041.91064
84/0.401.910
3 × 16+1 × 10126/0.401.64.030.333.315451.21085
84/0.401.910
3 × 25+1 × 16196/0.401.84.536.440.122690.780113
126/0.401.210
3 × 35+1 × 16276/0.401.84.540.544.627860.554138
126/0.401.210
3 × 50+1 × 16396/0.402.05.045.550.135540.386173
126/0.401.210
3 × 70+1 × 25360/0.502.05.051.555.145870.272215
196/0.400.780
备注:
2、产品标准:MT818.5-1999。
3、MT型电缆有4芯和5芯两种结构,有3根主线芯和一根地线芯组成(5芯电缆中有一芯为控制线),围绕垫芯绞合成缆,外面挤包氯化聚乙烯橡皮护套或黑色氯丁橡皮护套。
6、线芯识别:采用绝缘分色识别,主线芯红、绿、白。地线黑色。
7、成缆:主线芯、地线、围绕橡皮垫芯按右向绞合成缆。
8、护套:采用GB7594.7-1987中XH-03A型橡皮。护套橡皮的氧指数≥40。
9、成品电缆的阻燃性能满足MT386-1995的要求。
● 矿用移动橡套软电缆
型号(Type):UY 额定电压(Rating Voltage):380/660V
芯数截面
导体结构
绝缘厚度
护套厚度
Sheath thickness mm
电缆外径
Average diameter
参考重量
Cable approx.
weight
kg/km
导体(铜)最大直流电阻
Max.D.C.
20 ℃载流量
A
标称
Normianal mm
最大
Max
mm
3 × 4+1 × 4
56/0.30
1.4
3.5
20.3
23.4
637
4.950
35
56/0.30
4.950
3 × 6+1 × 6
84/0.30
1.4
3.5
23.0
26.4
856
3.300
46
84/0.30
3.300
3 × 10+1 × 10
84/0.40
1.6
4.0
27.5
31.3
1304
1.910
64
84/0.40
1.910
3 × 16+1 × 10
126/0.40
1.6
4.0
29.6
33.4
1545
1.210
85
84/0.40
1.910
3 × 25+1 × 16
196/0.40
1.8
4.5
35.6
39.8
2269
0.780
113
126/0.40
1.210
3 × 35+1 × 16
276/0.40
1.8
4.5
38.7
42.9
2786
0.554
138
126/0.40
1.210
3 × 50+1 × 16
396/0.40
2.0
5.0
43.6
47.9
3554
0.386
173
126/0.40
1.210
3 × 70+1 × 25
360/0.50
2.0
5.0
49.7
54.4
4587
0.272
215
196/0.40
0.780
备注:
2、产品标准:GB12972.5-1991。
3、UY型电缆是有3根主线芯和一根地线芯组成围绕垫芯绞合成缆,外面挤包氯化聚乙烯橡皮护套或黑色氯丁橡皮护套。
6、线芯识别:采用绝缘分色识别,主线芯红、绿、白、地线黑色。
9、普通型UY型成品电缆具有不延燃性能,阻燃型UY型成品电缆的阻燃性能满足MT386-1995的要求。
cable type current transformer - 电缆型电流互感器 (0) 投诉
P:2010-09-15 15:28:01
楼上是远东电缆的吧
high modulus secondary coating - 高模量二次涂层 (0) 投诉
P:2010-09-15 16:21:14
来这里的估计没几个是买电缆的吧?
广告的话效果不太好。
Z-alloy - Z合金<一种铝合金> (0) 投诉
P:2010-09-16 00:37:05
跟你说了是我们厂的矿用电缆介绍,如果你认为是广告的话,你可以不进来哦,至少这也是知识不是吗?总有人需要了解了解,可别做井底之蛙哦
secondary coating fiber - 一次涂层光纤,一次包覆光纤 (0) 投诉
P:2010-09-16 11:13:15
老兄:好像你的绝缘电阻不够哇
continuous wire extrusion machine - 连续挤线机 (0) 投诉
P:2010-09-20 08:15:24
真的耶
evaporation-cooled transmission line - 蒸发冷却输电线 (0) 投诉
P:2011-01-07 14:03:05
我要买矿用电缆,MYP 3*50+1*25 10米
oil expansion tank - 油平衡槽,油压平衡槽,压力箱 (0) 投诉
P:2011-04-19 10:38:43
你们厂还能参照英国的BS标准生产电缆吗?诺诺问一下,你们的电缆照英国BS标准来生产一根MYPTJ-3.6/6 70平方的电缆泄露电流值能达到多少啊?绝缘电阻(20℃)呢?
ACSR full size neutral messenger - 钢芯铝绞线用全尺寸中(性)线支承件 (0) 投诉
