首页 > 专业英语|国际贸易
[翻译求助] 跪求高人翻译下对方的要求
P:2010-08-24 14:31:57
| ITEM # | DESCRIPTION SPECIFICATIONS | QTES IN METER |
| 169205-KX6 | 7*0.19MM BC+3.75MM SPE+0.12MM*112CCA(20PITCH)+6.05MM PVC+2*(21*0.21MM BC+2.0MM PVC)+5.1MM PVC, BLACK | 200,000 |
| 191205-KX6 | 7*0.19MM BC+3.75MM SPE+0.12MM*112CCA(20PITCH)+6.05MM PVC+3*(21*0.21MM BC+2.0MM PVC)+5.75MM PVC, BLACK | 200,000 |
| KX6-110205 | 7*0.19MM BC+3.75MM SPE+0.12MM*112CCA(20PITCH)+6.2MM PVC,GREEN | 300,000 |
| R2V 3G-1.5 | 3*(1.35MM BC+2.72MM PVC)+8.87MM PVC,BLACK | 500,000 |
| R2V 3G-2.5 | 3*(1.73MM BC+3.1MM PVC)+9.7MM PVC,BLACK | 500,000 |
| R2V 4G-1.5 | 4*(1.335MM BC+2.72MM PVC)+9.7MM PVC,BLACK | 200,000 |
| R2V 4G-2.5 | 4*(1.73MM BC+3.12MM PVC)+10.6MM PVC,BLACK | 200,000 |
| R2V 5G-1.5 | 5*(1.35MM BC+2.72MM PVC)+10.35MM PVC,BLACK | 200,000 |
| R2V 5G-2.5 | 5*(1.715MM BC+3.1MM PVC)+11.2~11.7MM PVC,BLACK | 200,000 |
Z-shaped wire - Z形线 (0) 投诉
P:2010-08-25 11:56:46
此规格为二条平行线 第一条半成品为 7/0.19mm裸铜,绝缘是spe ID为3.75MM 加缠绕112条0.12MM铜包铝,绞距为20MM
第二条半成品为 导体为21/0.12MM裸铜,绝缘这PVC,ID为2.0MM 两芯绞合
被覆是6.05mm*5.1mm
steel reinforced aluminium wire - 钢芯铝绞线 (0) 投诉
