首页 > 专业英语|国际贸易
[翻译求助] UL2556的这词句怎么翻译
P:2010-08-20 15:21:32
The addition of the 0.08 mm (0.003 in) to the measured value does not apply to compact or compressed stranded conductors, or where a separator is used over the stranded conductor, or where measuring the thickness of a tape insulation
此语句在UL2556中4.1.5.1中提到,望高手指点
keystone strand wire rope - 楔形股绞钢丝绳(外表面由楔形钢丝股组成,以增强其耐磨性) (0) 投诉
P:2010-08-20 16:40:47
高手还在不
4.1.5.1 Minimum thickness at any point
The minimum thickness shall be as measured in Clause 4.1.4.1. When individual strands are less than
1.09 mm (0.043 in), and the measurement is made using the micrometer microscope method, 0.08 mm
(0.003 in) shall be added to the measured value. The addition of the 0.08 mm (0.003 in) to the measured
the stranded conductor, or where measuring the thickness of a tape insulation.
这是UL2556里一个章节提到的语句,望指点!
cable plow unit - 电缆敷设机 (0) 投诉
