首页 > 标准讨论 培训学习
[标准信息] 求IEC 60502-4:2005的中文版标准?
P:2010-08-14 08:40:16
IEC 60502-4
国 际 标 准 第1版
1997-03
额定电压1 kV(
挤出绝缘电力电缆及附件
第4部分:额定电压6kV(
电缆附件试验要求
Power cables with extruded insulation and their
Accessories for rated voltages from 1kV(
Up to 30kV(
Prat4:Test requirements on accessories for cables with rated voltages
From 6kV(
编号:CEI/IEC60502-4 1997
目 次
前言
1 范围······················································································································ 99
2 规范性引用文件····································································································· 99
3 定义······················································································································ 99
4 附件类型·············································································································· 101
5 电压的表示方法和最高导体温度··········································································· 101
6 被试附件的安装···································································································· 101
7 认可的范围··········································································································· 103
8 试验方法·············································································································· 103
9 试验程序·············································································································· 103
10 试验结果·············································································································· 104
表
1 用于可分离式终端试验的电缆截面········································································ 102
2 被试电缆绝缘的认可范围······················································································ 103
3 试验程序·············································································································· 104
4 终端的试验程序和要求························································································· 105
5 直通接头或分支接头的试验程序和要求································································· 106
6 绝缘罩的试验程序和要求······················································································ 107
7 屏蔽型不带电插拔式终端的试验程序和要求·························································· 108
8 非屏蔽型不带电插拔式终端的试验程序和要求······················································ 109
9 带负荷插拔式终端的试验程序和要求···································································· 110
11 最小和最大导体截面的附加试验············································································ 110
12 对不同型式的电缆绝缘屏蔽及从园形到成型导体认可的附加试验··························· 111
13 试验的项目汇总···································································································· 112
14 试验电压和要求的汇总························································································· 112
图
1 终端试品数量和试验布置······················································································ 113
2 接头试品数量和试验布置······················································································ 114
3 绝缘罩的试品数量和试验布置··············································································· 115
4 屏蔽型不带电插拔式终端的试品数量和式验布置··················································· 116
5 非屏蔽型不带电插拔式终端的试品数量和式验排列··············································· 117
6 带负荷插拔式终端的试品数量和试验布置····························································· 118
附录A 试验电缆的验证······························································································ 119
国际电工委员会
额定电压1kV(
挤出绝缘电缆及其附件
第4部分:额定电压6kV(
电缆附件试验要求
前 言
1) IEC(国际电工委员会)是一个由所有国家电工委员会(IEC国家委员会)组成的世界性标准化组织。IEC的目标是在电气和电子专业有关标准化的所有问题上促进国际合作。为 此IEC除了出版国际标准外,还进行一些其它活动。这些标准由受委托的各技术委员会制订。对关心所涉及的标准的任何IEC国家委员会可以参加制订工作。与IEC有协作关系的国际组织,政府机构和政府机构也可参加这种制订工作。IEC和国际标准化组织根据双方的协商条件密切合作。
2) 由于每个技术委员会代表所有国家委员会对他们关心的技术间题作出的IEC正式决议或协议尽可能表达出国际上对相关主题的一致意见。
3) 由这些正式议或协议的形成的文件以推荐形式在国际上使用,并以标准、技术报告或导 则的形式出版,在此意义上这些文件被各国家委员会所接受。
4) 为促进国际上的统一,IEC国家委员会同意明确地尽可能最大限度地在他们的国家标准和区域标准中采用IEC国际标准。在IEC标准和相应的国家标准或区域标准之间的任何差异应在后者中明确指出。
5) IEC不提供表示它被批准的标志的程序,而且不会对声称符合其一些标准之一的设备承担责任。
6) 要注意到本国际标准中的某些要素可能有专利权。IEC不应对辨认任何或所有这种专程权负有责任。
国际标准IEC 60502.4由IEC第20技术委员会(电缆)的第20A分技术委员会(高压电缆)制订。
本标准的文本以下列文件为依据:
国际标准出版稿 | 投票表决报告 |
absorption - 吸收,吸收作用 (1) 投诉
