首页 > 特种电缆
[光伏电缆] 光伏电缆料
P:2010-08-13 10:01:11
请各位高手指点一下光伏电缆料的相关材料、要求、工艺?
computer system monitor - 计算机系统监控器 (0) 投诉
P:2010-08-13 13:34:09
论坛上有发表
overcurrent - 过电流,过载电流 (0) 投诉
P:2010-08-13 14:00:08
我知道,但不全
small-size cable - 小尺寸电缆,小型电缆 (0) 投诉
P:2010-08-13 17:27:31
我也需要
low frequency signal transmission - 低频信号传输 (0) 投诉
P:2010-08-13 17:27:35
Table 4 – Requirements for halogen free insulation and sheath compounds
1 2 3 4 5 6 7
Test method described in Type of compounRef. d
No.
Test Unit
standard clause insulation sheath
1 Mechanical characteristics
1.1 Properties before ageing EN 60811-1-1 9.2
1.1.1 Values to be obtained for the tensile strength:
– median, min. N/mm2 6,5 8,0
1.1.2 Values to be obtained for the elongation at
break:
– median, min. % 125 125
1.2 Properties after ageing in oven EN 60811-1-2 8.1
1.2.1 Ageing conditions:
– temperature °C 150 ± 2 150 ± 2
– duration of treatment h 7 ´ 24 7 ´ 24
1.2.2 Values to be obtained for the tensile strength:c
– median, min. N/mm2 – –
– variation, max. % –30a –30a
1.2.3 Values to be obtained for the elongation at
break:c
– median, min. % – –
– variation, max. % – 30a – 30a
1.3 Hot set testd EN 60811-2-1 9
1.3.1 Conditions
– Temperature °C 200± 3 200± 3
– Time under load min 15 15
– mechanical stress N/cm2 20 20
1.3.2 Values to be obtained
– elongation under load, max. % 100 100
– permanent elongation after cooling, max. % 25 25
1.4 Thermal endurance properties EN 60216-2
1.4.1 Conditions
Either test of elongation at break or bending test
shall be performed.
– Temperature index 120 120
– elongation at break c % 50 50
– bending test EN 50305 7.2 2 D 2 D
1.5 Cold elongation test EN 60811-1-4 8.4
1.5.1 Conditions:
– temperature °C –40 ± 2 –40 ± 2
– duration h EN 60811-1-4 8.4.4 und 8.4.5 b b
1.5.2 Values to be obtained:
– elongation at break, min. % 30 30
multi-chamber quench furnace - 多室淬火炉 (0) 投诉
P:2010-08-13 17:29:29
直接上数据,爽吧,因为是表格,不好贴,但是绝对能看懂,只要是搞电缆的,除非LZ和菜鸟
lay changing gear - 节距变换齿轮 (0) 投诉
P:2010-08-24 08:55:37
苏州博思特新材料科技有限公司
http://www.--bosite-tpe.com
公司电话:0512-68585065   公司传真:0512-68585357
联系人:张生         手机:13295189559
公司地址:苏州市吴中区临湖镇木东路浦庄工业开发区
我司专业研发、生产和销售新颖高分子“合金”材料―――热塑性弹性体(Thermoplastic elastomer,缩写“TPE”),是国内弹性体知名企业之一,企业管理规范,研发能力雄厚,生产,检测设备先进,产品系列全面,质量稳定可靠,年产万余吨。公司率先通过ISO9001:2000质量管理体系认证,产品通过德国TUV,美国UL,欧盟ROHS,美国FDA和通标SGS等多种检测认证。目前,在全国设有多个办事处,售前和售后服务快捷周到,拥有广泛的客户群体。
本公司生产的热塑性弹性体材料,可广泛用于电线电缆,连接线插头,汽车配件,医疗器械,家居用品,电工资讯器材。可根据客户需要“量身定做”迅速开发能满足客户个性化需求的产品,如在强度、硬度、透明度、阻燃、耐高温、耐化学品性、耐油性、耐水性、耐磨性、亚光、亮光、高伸长率以及环保等方面的不同要求。
TPE、TPR特性:
1. 具备良好的触感, 可调整的物性,具备环保要求。
2. 无毒、无臭、无伤害
3. 优良的耐热性、耐低温性(-60);耐一般的化学品性及电器绝缘性
4. 无须硫化即具有硫化橡胶的特性
5. 加工时间短,生产效率高
6. 适合于注塑成型或挤出机加工成型
7. 边料、溢料可完全回收,降低成本(百分百回收)
8. 优异耐候性,对臭氧、紫外线、电弧有良好的耐受性
9. 密度低,单位重量利用率更高
10. 着色性能优秀:颜料分散均匀,不流痕,不褪色
11. 优良的电性能:体积电阻:10—10 ohm—cm,击穿电压强度;高压达39.3Mv/m
博思特主推产品:低烟无卤,无卤阻燃系列材料。阻燃级达到VW-1.
在电线电缆方面的应用:
为满足对低烟、无卤和高性价比的材料日益增长的需求,搏思特也进入到电线电缆行业中。搏思特TPE 、TPR 材料可用于电线电缆护套、一般家用电器的电源线、连接线等,是公认的环保材料。均通过UL1581\UL94V0测试。
产品应用: 连接器 * 开关 * 插座 * 计算器排线*室内外电线电缆护套
STC furnace - 短时间循环退火炉 (0) 投诉
P:2011-04-30 06:44:17
学习了
studio cable - 播音室电缆,传音电缆 (0) 投诉
P:2011-05-03 13:40:48
我也在学习啊
curing - 熟化,硫化;交联;硬化,硬化树脂 (0) 投诉
P:2011-05-13 15:50:47
需要了解光伏电缆料的 可加 我Q 详谈   513135855
electrostatic shield - 静电屏蔽 (0) 投诉
P:2011-06-23 13:04:21
我是上海凯波的,我们做光伏电缆用电缆料,这种料目前工艺已经十分成熟。如果你有需要,我们可以向你提供帮助,比如偏芯、高速挤出、解决模口流延等问题。李,电话:13482560292
control system automatically monitor - 控制系统自动监控器 (0) 投诉
