首页 > 国外线缆
[问题求助] 3053是什么线呀?
P:2007-03-29 16:24:54
3053是什么线呀?
transition joint box - 过渡接头盒 (0) 投诉
P:2007-04-07 11:02:32
具体说一下!
是不是AWM3053?
rollring unit - 滚环装置(排线装置上的排线器) (0) 投诉
P:2007-04-10 14:16:31
对~具体说一下啊
mass - 物质;电缆料;质量 (0) 投诉
P:2007-05-15 11:28:55
应该是UL电子线吧
其他的规格的型号里面好象没有这种编号形式的电线
transposition line - 换位线 (0) 投诉
P:2007-05-17 22:24:10
UNDERWRITERS LABORATORIES, INC.                 APPLIANCE WIRING MATERIAL
Subj.  758            Section   3          Page 3035   Issued:  May 1, 1959
                  This Page Effective   May 1, 1959
  Style 3035         Neoprene-Insulated Wire for Internal Wiring of
                    Refrigerating Equipment
  Rating             90 C, 300 Volts
  Conductor          7 No. 28 Awg copper strands, page 26
  Insulation         Nominal 3/64 inch wall neoprene, Class 17
  Covering           None
  Standard           Flexible Cord and Fixture Wire
  Instructions       Detailed examination
    to UL            Physical properties of insulation same as for Class
  Representative     17 neoprene
                    Spark test, page 30
                    Insulation resistance shall be not less than 1
                    megohm - 1000 ft.
     UL              (4) Detailed examination
  Counter-Check     (4) Physical properties of insulation same as for
  Program                Class 17 neoprene
  Marking            General, page 13
                    Manufacturer's marker not required.
                    Temperature marker required, pages 19, 20.
                    Items 7a, 7b, 7i, 8k, 9k.
  Use                For use only in Internal wiring of Lighting
                    Circuits in Refrigerating Equipment where exposed
                    to temperatures not exceeding 90 C.
low density polyethylene - 低密度聚乙烯 (0) 投诉
P:2007-05-18 21:08:36
看数字应该是UL的吧
takeup zone - 收线区(绞线机的) (0) 投诉
P:2011-07-27 17:49:40
UL电子线
halogen-free fiber optic cable - 无卤电缆,无卤阻燃电缆 (0) 投诉
P:2011-08-04 16:32:17
UL电子线
double thread worm - 双线螺杆 (0) 投诉
P:2011-08-05 11:15:48
UL hookur wire
phase separation - 相分离 (0) 投诉
