首页 > 国外线缆
[问题求助] UL21394相关知识!
P:2010-08-04 15:42:49
请问UL21394(30AWG)型号线材是属UL758 标准吗?其绝缘材质、被覆材质、环保、老化、燃烧试验、芯线绞距等等,都有哪些要求?请详细给予解答(有奖征答)!
MCL - muhipulling and cabling in line在线多线牵引和成缆;多头拉丝和成缆生产线 (0) 投诉
P:2010-08-04 19:09:45
怎么没有人跟帖啊
CMIP - common management lnformation protocol通用管理信息协议 (0) 投诉
P:2010-08-31 13:13:07
UNDERWRITERS LABORATORIES
APPLIANCE WIRING MATERIAL
Subj.758
Section 2
Page 21394
Issued:2004-12-13
Revised:2008-05-27
Style 21394
Jacketed cable.
Rating
80 deg C, 30 Vac, Horizontal flame.
Insulation
Labeled or complies with manufacturer's AWM Procedure.
Assembly
Two, three, or four parallel, or two or more twisted insulated singles or groups of twisted singles twisted together or groups of twisted singles may be laid parallel to form flat or oval cable. Barrier layer and/or fillers optional. Manufacturer shall maintain a complete description of each assembly. Diameter of assembly under jacket shall be one inch maximum.
Shield
Optional.
Jacket
TPE, 15 mils min average, 12 mils minimum at any point.
Standard
Appliance Wiring Material UL 758.
Marking
General.
Use
Internal wiring of electronic equipment in Class 2 Systems only.
aerial rural distributing wire - 架空农用配电线 (0) 投诉
P:2010-09-03 13:51:24
佛山市卓晟环保电线有限公司有生产低烟无卤护套线UL21394  HF ,额定温度80℃,额定电压30V,通过UL,CUL认证,无卤环保。
电话:0757-86331713 传真:0757-86322227  zhuosheng#gmail.com (发送电子邮件请将#改为@)  网站:http://www.--greenwire.cn
uniform major section - 均匀大段(由三个基本上相等的单元段组成) (0) 投诉
