首页 > 型号析疑 产品报价
[型号解析] SFX-50-3什么意思? 烦高人指点,有无相关标准
P:2010-08-02 14:39:31
overhead pay-off-rack - 越端放线架 (0) 投诉
P:2010-11-29 12:56:43
应该是同轴线缆。不了解      期待中、、、、、、、、、、、
PEWC - Pacific Electric Wire&Cable Co.太平洋电线电缆公司(中国台湾省最大的线缆制造商) (0) 投诉
P:2010-12-07 09:03:01
不了解~~~~~~~~`
dead angle - 死角(模具设计的) (0) 投诉
P:2011-02-22 12:27:08
 实芯聚四氟乙烯绝缘半柔同轴射频电缆  实芯聚四氟乙烯绝缘半柔射频电缆,具有屏蔽性好、使用频率高、驻波比小、功率大、可靠性高等各种特点,相对于半硬电缆更柔软,可多次重复弯折。该类电缆适用于微波、射频设备和移动基站、延迟线和其它电子设备的信号连线 二、 电缆代号及型号:</DIV>
 四、使用特性 工作温度:  -55~165℃ (SFX及SFXF                -20~90℃  (SFXH 五、结构数据及主要性能 SFX  实芯聚四氟乙烯绝缘半柔同轴射频电缆
<DIV align=center>型号</DIV><DIV align=center>内导体</DIV><DIV align=center>根数/直径</DIV><DIV align=center>mm</DIV><DIV align=center>标称</DIV><DIV align=center>绝缘外径</DIV><DIV align=center>mm</DIV><DIV align=center>标称</DIV><DIV align=center>电缆外径</DIV><DIV align=center>mm</DIV><DIV align=center>标称</DIV><DIV align=center>特性阻抗</DIV><DIV align=center>Ω</DIV><DIV align=center>衰减常数</DIV><DIV align=center>≤dB/100m</DIV><DIV align=center>试验</DIV><DIV align=center>电压</DIV><DIV align=center>kV</DIV><DIV align=center>最小弯曲半径</DIV><DIV align=center>mm</DIV>
<DIV align=center>1GHz</DIV><DIV align=center>3GHz</DIV>
10GHz
<DIV>SFX-50-1</DIV><DIV align=center>SC1/0.28</DIV><DIV align=center>0.92</DIV><DIV align=center>1.18</DIV><DIV align=center>50</DIV><DIV align=center>148</DIV><DIV align=center>268</DIV><DIV align=center>562</DIV><DIV align=center>2.0</DIV><DIV align=center>4.5</DIV>
<DIV>SFX-50-2</DIV><DIV align=center>SC1/0.51</DIV><DIV align=center>1.68</DIV><DIV align=center>2.18</DIV><DIV align=center>80.2</DIV><DIV align=center>120.0</DIV><DIV align=center>287.5</DIV><DIV align=center>5.0</DIV><DIV align=center>6.0</DIV>
<DIV>SFX-50-2-1</DIV><DIV align=center>SCT1/0.51</DIV><DIV align=center>1.68</DIV><DIV align=center>2.18</DIV><DIV align=center>80.2</DIV><DIV align=center>120.0</DIV><DIV align=center>287.5</DIV><DIV align=center>5.0</DIV><DIV align=center>6.0</DIV>
<DIV>SFX-50-3</DIV><DIV align=center>SC1/0.94</DIV><DIV align=center>2.98</DIV><DIV align=center>3.58</DIV><DIV align=center>39.4</DIV><DIV align=center>68.9</DIV><DIV align=center>144.7</DIV><DIV align=center>5.0</DIV><DIV align=center>11</DIV>
<DIV>SFX-50-3-1</DIV><DIV align=center>SCT1/0.94</DIV><DIV align=center>2.98</DIV><DIV align=center>3.58</DIV><DIV align=center>39.4</DIV><DIV align=center>68.9</DIV><DIV align=center>144.7</DIV><DIV align=center>5.0</DIV><DIV align=center>11</DIV>
<DIV>SFX-50-5</DIV><DIV align=center>SC1/1.63</DIV><DIV align=center>5.30</DIV><DIV align=center>6.0</DIV><DIV align=center>24.6</DIV><DIV align=center>52.5</DIV><DIV align=center>108.3</DIV><DIV align=center>7.5</DIV><DIV align=center>16</DIV>
</DIV><DIV>注:SFX-50-5相当于RG401,SFX-50-3相当于1673,SM141,RG402,SFX-50-2相当于1671,SM086,RG405,SFX-50-1相当于SM047。</DIV><DIV>可以根据需要提供12.5、25、35、75、95等特性阻抗的半柔电缆,除阻抗不同其余参数不变。</DIV><DIV> </DIV><DIV align=center>SFXF  SFXH  实芯聚四氟乙烯绝缘带护套半柔同轴射频电缆</DIV><DIV>五、结构数据及主要性能(续):</DIV><DIV align=center>
10GHz
<DIV>SFXF-50-1</DIV><DIV align=center>SC1/0.28</DIV><DIV align=center>0.92</DIV><DIV align=center>1.55</DIV><DIV align=center>50</DIV><DIV align=center>124.5</DIV><DIV align=center>187.2</DIV><DIV align=center>378.7</DIV><DIV align=center>2.0</DIV><DIV align=center>5.0</DIV>
<DIV>SFXF-50-2</DIV><DIV align=center>SC1/0.51</DIV><DIV align=center>1.68</DIV><DIV align=center>2.70</DIV><DIV align=center>80.2</DIV><DIV align=center>120.0</DIV><DIV align=center>287.5</DIV><DIV align=center>5.0</DIV><DIV align=center>6.0</DIV>
<DIV>SFXF-50-2-1</DIV><DIV align=center>SCT1/0.51</DIV><DIV align=center>1.68</DIV><DIV align=center>2.70</DIV><DIV align=center>80.2</DIV><DIV align=center>120.0</DIV><DIV align=center>287.5</DIV><DIV align=center>5.0</DIV><DIV align=center>6.0</DIV>
<DIV>SFXF-50-3</DIV><DIV align=center>SC1/0.94</DIV><DIV align=center>2.98</DIV><DIV align=center>4.20</DIV><DIV align=center>39.4</DIV><DIV align=center>68.9</DIV><DIV align=center>144.7</DIV><DIV align=center>5.0</DIV><DIV align=center>11</DIV>
<DIV>SFXF-50-3-1</DIV><DIV align=center>SCT1/0.94</DIV><DIV align=center>2.98</DIV><DIV align=center>4.20</DIV><DIV align=center>39.4</DIV><DIV align=center>68.9</DIV><DIV align=center>144.7</DIV><DIV align=center>5.0</DIV><DIV align=center>11</DIV>
<DIV>SFXF-50-5</DIV><DIV align=center>SC1/1.63</DIV><DIV align=center>5.30</DIV><DIV align=center>6.10</DIV><DIV align=center>24.6</DIV><DIV align=center>52.5</DIV><DIV align=center>108.3</DIV><DIV align=center>7.5</DIV><DIV align=center>16</DIV>
<DIV>SFXH-50-1</DIV><DIV align=center>SC1/0.28</DIV><DIV align=center>0.92</DIV><DIV align=center>2.00</DIV><DIV align=center>50</DIV><DIV align=center>124.5</DIV><DIV align=center>187.2</DIV><DIV align=center>378.7</DIV><DIV align=center>2.0</DIV><DIV align=center>5.0</DIV>
<DIV>SFXH-50-2</DIV><DIV align=center>SC1/0.51</DIV><DIV align=center>1.68</DIV><DIV align=center>3.00</DIV><DIV align=center>80.2</DIV><DIV align=center>120.0</DIV><DIV align=center>287.5</DIV><DIV align=center>5.0</DIV><DIV align=center>6.0</DIV>
<DIV>SFXH-50-2-1</DIV><DIV align=center>SCT1/0.51</DIV><DIV align=center>1.68</DIV><DIV align=center>3.00</DIV><DIV align=center>80.2</DIV><DIV align=center>120.0</DIV><DIV align=center>287.5</DIV><DIV align=center>5.0</DIV><DIV align=center>6.0</DIV>
<DIV>SFXH-50-3</DIV><DIV align=center>SC1/0.94</DIV><DIV align=center>2.98</DIV><DIV align=center>4.50</DIV><DIV align=center>39.4</DIV><DIV align=center>68.9</DIV><DIV align=center>144.7</DIV><DIV align=center>5.0</DIV><DIV align=center>11</DIV>
<DIV>SFXH-50-3-1</DIV><DIV align=center>SCT1/0.94</DIV><DIV align=center>2.98</DIV><DIV align=center>4.50</DIV><DIV align=center>39.4</DIV><DIV align=center>68.9</DIV><DIV align=center>144.7</DIV><DIV align=center>5.0</DIV><DIV align=center>11</DIV>
<DIV>SFXH-50-5</DIV><DIV align=center>SC1/1.63</DIV><DIV align=center>5.30</DIV><DIV align=center>7.50</DIV><DIV align=center>24.6</DIV><DIV align=center>52.5</DIV><DIV align=center>108.3</DIV><DIV align=center>7.5</DIV><DIV align=center>16</DIV>
</DIV><DIV>注:1.F为氟塑料护套,H为PV塑料护套。</DIV><DIV>      2.可以根据需要提供12.5、25、35、75、95等特性阻抗的半柔电缆,除阻抗不同其余参数不变</DIV></DIV>
</DIV>
[yiyi5566 在 2011-2-22 15:38:08 编辑过]
cable-sheathing compound - 电缆护套料 (0) 投诉
P:2011-02-24 14:15:04
不同的单位命名不同,应当是半柔电缆的!
open-cell plastic foam - 开孔泡沫塑料 (0) 投诉
P:2011-11-06 21:29:37
是半柔同轴电缆
die core - 模芯(拉线模的) (0) 投诉
