首页 > 国外线缆
[问题求助] 请问:1016,1081是什么电线
P:2010-07-20 18:21:02
请各位高手告之1016,1081这两种线的工艺结构
corrugating - 轧纹 (0) 投诉
P:2010-07-20 19:31:21
UL標準的電子線
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 1       Page 1061        Issued:  1959-05-01
                                    Revised:  2007-04-24
Style 1061
Semi-Rigid PVC or SRPVC Insulated Wire.
Rating
80°C, 300 Volts.
*Conductor
30-16 AWG, solid or stranded.
Insulation
Semi-Rigid PVC (SRPVC):  9 mils minimum average, 7 mils minimum at any point.
Standard
Appliance Wiring Material UL 758.
Instructions
to UL
Representative
Detailed Examination.
Physical Properties, Unaged.
Spark Test.
UL
Counter-Check
Program
(4)  Detailed Examination.
(4)  Physical Properties.
(4)  Heat Shock.
(4)  Cold Bend.
(4)  Deformation.
(12) Horizontal Flame Test.
Marking
General.
Use
Internal Wiring in Electric Bookkeeping, Accounting,
Time-Recording Machines, or Electronic Equipment
if within a chassis or protected from mechanical injury.
alcohol pickling unit - 乙醇酸洗装置 (0) 投诉
P:2010-07-20 19:32:18
UNDERWRITERS LABORATORIES, INC.                   APPLIANCE WIRING MATERIAL
Subj.  758              Section   1          Page 1081   Issued:  May 1, 1959
                                                     Revised: Feb. 26, 1969
  Style 1081           Thermoplastic (PVC) - Insulated Wire For Use
                      In Internal Wiring of Refrigerating Equipment.
  Rating               105 C, 300 Volts.
  Conductor            Minimum 0.0025 inch diameter resistance wire
*                     wound for a minimum 20 turns per inch on a
                      Fortisan, Polyester yarn, or Fiberglas yarn core.
  Insulation           Nominal 1/32-Inch wall of Thermoplastic (PVC).
                      Compounds suitable for use at 105 C.
  Covering             Extruded Zytel 33 nylon in 2-Mil minimum thickness.
  Standard             Flexible Cord and Fixture Wire.
  Instructions         Detailed examination.
      to UL             Tensile strength and elongation of insulation,
  Representative       Class 12.
                      Spark Test, page 30.
     UL                (4) Detailed examination.
  Counter-Check       (4) Tensile strength and elongation of insulation,
  Program                  page 33.
                      (4) Heat Shock, page 37.
                      (4) Deformation, page 38.
                      (4) Cold Bend, page 39.
                      (2) Flame Test, page 31.
  Marking              General, page 13.
                      Manufacturer's marker required, pages 3, 18, 19.
                      Items 2a, 2i, and where the nylon is transparent
                      3k, 4n.
                      Temperature marker required, pages 19, 20.
                      Items 7a, 7i and where the nylon is transparent
                      8k, 9k, 10n.
  Use                  Internal Wiring of Electric Refrigerators
                      where exposed to temperatures not exceeding 105 C
                      and where not subjected to flexing or motion.
FWHM - full width at half maximum线极值一半全宽度,最大半振幅的全宽度 (0) 投诉
P:2010-07-21 11:44:41
哈哈。他是要1016的哦。。。
ba是要1061的!
pusher type furnace for ingot - 推进式线锭加热炉 (0) 投诉
P:2010-07-21 18:15:13
谢谢版主
orbiling head for coreless coiler - 带槽的无芯成圈机头 (0) 投诉
