首页 > 求购信息
[求购信息] 特种电缆 高手看下
P:2010-07-01 08:29:05
你好请问你们有没有这种电话线?19, 22, 24 and 26 AWG
ALP Air Core, Figure-8 Self-Supporting
RUS/RDUP Spec PE-38
For aerial installation using standard methods and hardware.
RUS/RDUP Designation: CAK
Electrical Characteristics: See Table A on page 21 in this section.
Conductors Solid, annealed bare copper in 19, 22, 24 and 26 AWG
Insulation Solid, color-coded polyolefin
Twisted Pairs Individual insulated conductors are twisted into pairs with varying lay lengths
Core Assembly
Cables of 25 pairs or less are assembled into a cylindrical core. Cables larger than 25
pairs are assembled into units, which are then used to assemble the core. Units are
individually identifiable by color coded unit binders.
Core Wrap Non-hygroscopic, dielectric tape
Support Member
A 1/4", 7-strand Extra High Strength (EHS) galvanized steel messenger serves as the
support member and is an integral part of the sheath. The messenger is flooded to
inhibit corrosion.
Shielding Corrugated, copolymer coated, .008" aluminum tape applied longitudinally with an overlap
Outer Jacket Black, linear low-density PE designed to withstand exposure to direct sunlight, atmospheric
temperature changes and stresses expected in standard installations
Footage Marking Printed sequentially every 2' along the outer jacket
dripping test - 滴流试验 (0) 投诉
P:2010-07-01 08:34:14
湖北三佳 电线电缆 15071248365      有你需要的
er-doped fiber - 掺铒光纤 (0) 投诉
P:2010-07-01 09:08:53
忽悠吧
varnish - 清漆 (0) 投诉
P:2010-07-01 09:59:15
应该是自承是话缆
pneumatic device for change-over of take-up spool - 气动收线换盘装置 (0) 投诉
