首页 > 国外线缆
[问题求助] UL Style Page解释说明
P:2010-05-26 15:59:54
| UNDERWRITERS LABORATORIES | APPLIANCE WIRING MATERIAL | ||||
| Subj.758 | Section 1 | Page 10934 | Issued:2005-01-27 |
| Revised:2008-05-27 | |||
| Style 10934 | Jacketed Cable. | |
| Rating | 80 deg C, 300 Vac, Cable flame, Oil Resistant 60 deg C (optional). |
| Conductor | 32 AWG - 2 AWG solid or stranded round, tinned or bare copper. |
| Insulation | Labeled or complying with manufacturer's AWM procedure. |
| Assembly | Nonmetallic fibrous mechanical strength member may be provided under jacket. Cable may be in the form of helix. |
| Shield | Optional. |
| Jacket | TPU. 33 mils min average, 26 mils minimum at any point. |
| Standard | Appliance Wiring Material UL 758. |
| Marking | General. |
| Use | Internal wiring or external interconnection of electric or electronic equipment, or Internal wiring or external interconnection of electric or electronic equipment where exposed to a temperature not exceeding 80 deg C in air or 60 deg C in oil. 各位大俠: 以上的UL10934 Style Page標準未規定Covering,是否可以做中層被覆和雙外被的規格?另外指定Jacket材質為TPU,是否可用TPE材料生產,因為TPE也包含TPU材料; 請多多指教!!! 謝謝!!! |
dispersion compensating fiber - 色散补偿光纤 (0) 投诉
