首页 > 国外线缆
[问题求助] 做好的2468铜包铝线氧化了还能用吗?
P:2010-05-12 20:39:05
| UNDERWRITERS LABORATORIES | APPLIANCE WIRING MATERIAL | ||||
| Subj.758 | Section 2 | Page 2468 | Issued:1968-05-07 |
| Revised:2008-05-27 | |||
| Style 2468 | Flat Ribbon cable. | |
| Rating | 80 deg C, 300 Vac, Horizontal flame, Oil Resistant 60 deg C or 80 deg C (optional). |
| Conductor | 32 AWG - 16 AWG solid or stranded round, tinned or bare copper.(铜) |
| Insulation | PVC, 15 mils min average, 13 mils minimum at any point. |
| Assembly | Two to one hundred and fifty conductors laid parallel and in one plane. Same or mixed AWG. Each conductor has a nominal 15 mils or heavier wall. This forms a flat cable with a single row of conductors having a 1/2 in. maximum width web between insulated conductors. |
| Shield | Optional. |
| Covering | (Optional) PVC, 5 mils min. at any point 80 mils max |
| Standard | Appliance Wiring Material UL 758. |
| Marking | General. |
| Use | Internal wiring of Appliances; or internal wiring of Appliances where exposed to oil at a temperature not exceeding 60 deg C or 80 deg C, whichever is applicable. |
[刪蒢記憶 在 2010-5-12 20:39:31 编辑过]
roll adjustment set - 轧辊调节装置 (0) 投诉
22
