首页 > 国外线缆
[技术资料] 谁有1061,1007的标准啊 ?
P:2010-05-10 12:59:26
谁有1061,1007的标准啊 ?
BIS - Business Information System行业情报系统 (0) 投诉
P:2010-05-10 13:53:44
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 1Page 1007Issued:1959-05-01
Revised:2008-05-27
Style 1007Insulated Wire.
Rating80 deg C, 300 Vac, Horizontal flame, Oil Resistant 60 deg C or 80 deg C (optional).
Conductor32 AWG - 16 AWG Solid or Stranded.
InsulationPVC, 15 mils minimum average, 13 mils minimum at any point.
StandardAppliance Wiring Material UL 758.
MarkingGeneral.
UseInternal wiring of appliances; or where exposed to oil at a temperature not exceeding 60 deg C or 80 deg C, whichever is applicable. Tags may indicate the following: 600 V Peak - For Electronic Use Only
mass terminable cable - 整体终端电缆 (0) 投诉
P:2010-05-10 13:54:29
Subj.758Section 1Page 1061Issued:1959-05-01
Revised:2008-05-27
Style 1061SRPVC Insulated Wire.
Rating80 deg C, 300 Vac, Horizontal flame.
Conductor30 AWG - 16 AWG solid or stranded.
InsulationSRPVC, 9 mils minimum average, 7 mils minimum at any point.
MarkingGeneral.
UseInternal Wiring in Electric Bookkeeping, Accounting, Time-Recording Machines, or Electronic Equipment if within a chassis or protected from mechanical injury.
gross weight - 毛重,总重 (0) 投诉
P:2010-05-10 14:05:41
在资料共享里就能搜得到的。如果不是你想要的版本,求助时请说明。
flight width - 螺纹宽度(螺杆的) (0) 投诉
P:2010-05-10 14:06:15
英文的啊
infrared transmission - 红外传输,红外线传输 (0) 投诉
P:2010-05-10 14:32:34
呵呵,这个还有中文的啊!
fiber beat length - 光纤拍长 (0) 投诉
P:2010-05-11 07:39:40
1007,1061不是标准,只是UL其中的STYLE  PAGE!你上UL网站查就是了!
backend - 末端,尾端 (0) 投诉
P:2010-05-11 12:51:42
  谢谢了
addressable converter - 可寻址变换器<有线电视> (0) 投诉
P:2010-05-17 23:41:54
不是标准,是UL型号
drawing force - 拉线力 (0) 投诉
P:2010-05-18 21:55:49
这太简单了
double-headed binding jack - 双头捆扎装置 (0) 投诉
P:2010-09-15 13:16:01
我也想要UL系列标准!
virtual call - 虚呼叫 (0) 投诉
P:2010-10-16 11:31:03
看公司的UL认证细则,很详细的!
FWHM - full width at half maximum线极值一半全宽度,最大半振幅的全宽度 (0) 投诉
P:2010-10-24 22:47:33
STYLE PAGE上UL主网站,透过IQ可以查的到滴
cross-modulation - 交叉调制,交扰调制 (0) 投诉
