首页 > 线缆机器设备
[绞制设备] 适合绞四芯的成缆机
P:2010-04-30 11:01:38
1250mmφ x 4 cores Planetary type Laying-up Machine. (Taper type)
A.Main specification ─
a. Usage : For 4 core or 5 core cable laying up .
b. Type : Taper type stranding, can be select the
pay-off unit back-twist or non back-twist type.
c. Pay-off bobbin size : 1250 mmφ / Max.
(Pay-off bobbin are excluded)
d. Wire inlet :
d-1. Round core : 10~200 m㎡ each core
d-2. Pre-spiral sector : 50~250 m㎡ each core
d-3. Straight sector : 50~180 m㎡ each core
e. Finish laying-up diameter :
laying up of 4 or 5 cores, aluminum or copper insulated
conductor up to 80 mmφ/ Max.
f. Line speed of rotary : 0 - 30 RPM.
g. Line Speed : 90 MPM / Max.
h. Power : Main motor : 30 Hp DC/4Q Motor (1150 RPM)
Tapping Machine : 7 1/2HP DC/4Q Motor (1750 RPM)
Caterpillar unit : 10 Hp DC/2Q Motor (1750 RPM)
Take-up motor : 10 HP DC Motor.
i. Each core diameter : 5 - 30mmφ
j. Pitch range : 150 - 3000mm.
k. Power Source : Meet your local power source.
l. Bobbin loading & unloading: By overhead electric hoist. (optional)
m. Safety device : Guards open
Motors fault
n. Spooler wire tension control : By DC-Torque motor.
Stockbridge vibration damper - 架空明线减振器 (0) 投诉
