首页 > 国外线缆
[问题求助] 有谁知道这是什么型号的线?
P:2010-04-27 09:32:15
各位,有谁知道这是什么型号?AWM STYLE 2789 60C 30V VW-1 AWM I/II A/B 80C 30V FT1   1107
five-wire conductor - 五线组 (0) 投诉
P:2010-04-27 10:29:35
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subject 758 Section 2 Page 2789 Issued: May 21, 1976
Revised: Feb. 2, 2001
Style 2789 PVC Jacketed Cable.
______________________________________________________________________________
Rating 60°C, 30 V.
Insulated Labeled or complies with this Manufacturers AWM Singles
procedure.
Conductor Two or more insulated singles or groups of insulated singles
Assembly cabled together to form a flat, oval or round assembly.
* Barrier layer and/or fillers optional. May use same or
mixed AWG size. Manufacturer shall maintain a complete
description of each assembly.
Covering (Optional) - 5 mil min. PVC covering may be extruded over
the conductor assembly or PTFE, PFA, FEP, ETFE covering,
8 mils min. average, 6 mils minimum at any point.
*Shield Optional.
Covering (Optional) - 5 mil min PVC covering may be extruded over the
conductor assembly or PTFE, PFA, FEP, ETFE covering, 8 mils
min average, 6 mils min at any point.
*Shield Optional.
*Jacket PVC, Class 43,
THICKNESS OF JACKET (Mils)
Major dia of Minimum
Assembly under Minimum At Any
Jacket# (inch) Average Point
0.700 or less 30 24
0.701 - 1.000 45 36
1.001 - 1.500 60 48
1.501 - 2.500 80 64
2.501 - 4.00 110 88
4.001 or larger 140 112
# - Major dia if cable is flat or oval.---------------全在这写着呢
ocean bottom cable burying skid - 海底埋缆撬 (0) 投诉
P:2010-04-27 21:21:39
呵呵,楼上说的对
distribution board - 配线盘,配电盘 (0) 投诉
P:2010-05-07 23:05:37
UL2789
cu ft - cubic foot立方英尺 (0) 投诉
P:2010-05-19 10:48:57
I/II A/B
paraffine wire - 石蜡绝缘线,蜡克线 (0) 投诉
P:2010-05-19 11:33:13
2789噻
PE insulated plastic sheathed cable - 聚乙烯绝缘塑料护套电缆 (0) 投诉
P:2010-05-19 15:16:25
不知道
aggregatoin - 聚沉 (0) 投诉
P:2010-05-20 15:00:22
最后的1107 是什么没看懂
higher-order-mode filtering - 高次模滤波 (0) 投诉
P:2010-05-20 19:09:41
不知道
miniaature diameter coaxial cable - 微同轴电缆 (0) 投诉
P:2010-05-22 21:20:04
估计是其不同工厂的代号
nickel-plated wire - 镀镍线 (0) 投诉
P:2010-06-16 18:03:43
上面的英文一点都看不懂呀
congealing point - 冷凝点 (0) 投诉
P:2010-06-17 13:52:21
不明白啊
multiple wire-treatment unit - 多头线材处理设备 (0) 投诉
