[问题求助] 请高人指点以下几种料的区别:BS EN 50363
P:2010-03-08 18:25:45
如题:
BS EN 50363, Type TI 3
BS EN 50363-3, Type TI 3
BS EN 50363, Type TM 3
BS EN 50363-4-1, type TM 3
感激不尽,谢谢
ampere conductor - 安培导体 (0) 投诉
P:2010-03-10 10:51:27
我只能找到以下内容,至于TM3,实在是找不到了
Type TI 3 to BS EN 50363-3
Test
Unit
Requirement
Minimum oxygen index (ISO 4589-2).
26
Minimum tensile strength before ageing.
N/mm²
15.0
Minimum elongation before ageing.
150
Minimum tensile strength after ageing at 135±2°C for 14 days.
Maximum variation.
N/mm²
15.0
±25
Minimum elongation after ageing at 135±2°C for 14 days.
Maximum variation.
150
±25
Loss of mass after ageing at 115±2°C for 14 days.
mg/cm²
1.5
Heat shock test at 150°C for 1 hour.
No cracks and no shrinkage
Pressure test at 90±2°C.
Maximum indentation.
50
Bending test at -15±2°C.
No cracks
Thermal stability at 200°C.
Minimum.
min.
240
继续等候高人指点
intermediate frequency - 中频 (0) 投诉
P:2012-05-15 12:15:10
straight-through drawing - 贯穿式拉线(线从一个鼓轮直接引往下一道模子和下一道鼓轮,中间不通过越端放线的过渡形式) (0) 投诉
P:2012-05-22 09:54:43
傻帽,名字不一样嘛。这都没看出来,悲剧了你。
aberration - 色差 (0) 投诉
P:2012-09-21 22:57:54
Low Tension - 低压。如使用在汽车之电线,电池与啟动马达之电线,汽车灯光用电线等。 (0) 投诉
P:2013-07-22 15:45:07
浪费我金币
weak-current cable - 弱电流电缆 (0) 投诉
P:2013-07-24 15:00:14
aerial bunched cable - 架空成束电缆 (0) 投诉
