首页 > 特种电缆
[问题求助] 请问哪家的交联PVC和交联PE做的比较好?
P:2010-06-12 11:52:06
电线电缆用辐照交联聚氯乙烯电缆料
Irradiation cross-linked PVC compound
1、 产品型号、用途
ⅰ、Type and application
型号 Type | 名称 Product | 用途及电缆规范 Application and Cable Specification |
1151N | 线芯工作温度 Used for irradiation cross-linked cable and wires which working temp of conductor is |
2、 产品说明
电线电缆用辐照交联聚氯乙烯绝缘料是以聚氯乙烯树脂为基料,加入增塑剂、稳定剂、颜料等助剂,经混合、塑化、造粒而制得的粒状料。产品系列化:可增加不同硬度、耐侯耐紫外线、环保(RoHs、 PAHs、无DOP、无氯化烷烃、无邻苯类等)、亚光雾面、耐低温、耐PS/ABS迁移、防鼠咬、防白蚁、透明等各种特殊性能。
ⅱ、Irradiation cross-linked PVC insulating compound for wires and cables, based on PVC resin ,is made into granula by mixing, plastification and granulation with adding plasticizer, stabilizing agent, pigment and etc .The products meet various special requirements,such as different hardness,Uv stable,enviroment friend (RoHs,PAHs,DOPfree,chlorinated alkanes free,phthalate free,and ect.) sub-shine and fog surface,low temperature resistant ,PS/ABS transfer proof,rodent-repellent,termite-repellent,and tansparent,and etc.
3、加工工艺
采用一般挤出机加工,L/D≥20。
ⅲ、Processing:
It is recommended that compound should be processed with common extruder having a minimum L/D ratio of 20.
推荐挤出机各区点设定温度如下:
The following temperature(℃) profile of extruder is recommended:
区点 Zone | 1区 Zone 1 | 2区 Zone 2 | 3区 Zone 3 | 4区 Zone 4 | 机头 Head | 模头 Die |
温度 Temperature ℃ | 140 | 160 | 170 | 175 | 180 | 175 |
4、储存与运输
包装:25kg一袋,聚乙烯薄膜内袋,牛皮纸复合袋外包装。
运输与储存:电缆料在运输过程中不应受日晒雨淋,应储存在清洁、阴凉、干燥、通风的仓库内。
ⅳ、Storage and transport
Packaging:25kg/bag, PE membrane inside bag and Kraft outside bag.
Storage and transport: Avoiding in direct sunlight and weathering. The storage place should be in clean, cool, dry, and ventilated conditions.
autoswitch - 自动开关 (0) 投诉
P:2010-06-12 11:54:53
5、产品性能
Ⅴ、Properties
表Table
试验项目 Item | 单位 Unit | 1151N | |
标准值 Standard Value | 典型值 Typical | ||
抗拉强度 Tensile Strength | ≥ MPa | 16.0 | 20.5 |
断裂伸长率 Elongation at Break | ≥ % | 150 | 285 |
冲击脆化温度 Impact Brittleness Temperature | ℃ | -15 | 通过 |
Volume Resistivity, at 20℃ | ≥ Ω﹒m | 1.0×1011 | 3.0×1011 |
工作温度体积电阻率 Volume Resistance a tworking temperature | ℃ | 95±1 | 95 |
≥ Ω﹒m | 1.0×108 | 2.0×1010 | |
介质损耗因数(50Hz) Dielectric Loss Factor | ≤ | ------- | ------- |
介电强度 Dielectric Strength | ≥ MV/m | 20 | 26 |
Santonox - 森托诺克斯(一种聚乙烯抗氧剂商品名) (0) 投诉
P:2010-06-12 11:55:21
热变形 Hot Deformation | ≤ % | 40 | 20 |
Thermal Stability Time at | ≥ min | 120 | 130 |
氧指数 Oxugen Index | ≥ % | 28 | 28.6 |
热延伸 负载下伸长率 Thermal Prolongation Elongation Under Load | ≤ % | 175 | 30 |
比重 Density | g/cm3 | 1.35±0.01 | 1.35 |
硬度 Hardness | Shore A | 86±2 | 86 |
热老化 Thermal Aging | |||
热老化温度 Aging Temperature | ℃ | 136±2 | 136±2 |
热老化时间 Aging Time | h | 168 | 168 |
抗拉强度保留率 Retention on Tensile Strength | % | +80 | 102 |
断裂伸长率保留率 Retention on Elongation at Break | % | +75 | 89 |
注:以上为辐照交联后的性能 Note:The above data are the compound properties after irradiated.
die polishing machine - 线模抛光机 (0) 投诉
