首页 > 专业英语|国际贸易
[翻译求助] 帮忙翻译一份订单
P:2010-03-02 11:40:08
Please send your best prices for the best quality of the following cable. Cables low voltage (U1000) :
  1. 2x16 mm2 Alu arial according to the french standard NF C 33 209(7000meter)
  2. 4x16 mm2 Alu underground according to the french standard NF C 33 210(5000M)
  3. 4x50 mm2 Alu underground  armed according to the french standard NF C 33 210(2000M)
  4. 3x95 + 50 mm2 Alu underground  armed according to the french standard NF C 33 210(1500M)
  5. 3x150+70 mm2 Alu underground  armed according to the french standard NF C 33 210(1000M)
  6. 3x240+95 mm2 Alu underground  armed according to the french standard NF C 33 210(1000M)
  7. 1x240 mm2 Alu ARO2V(1000M)
Cables medium voltage (12/20 kV) according to the french standard NF C 33 223  or NF C 33 226: Aluminum
  1. 1x50 mm2(1000M)
  2. 3x1x150 mm2 assembled on torsade (twisted)(1500M)
  3. 3x1x240 mm2 assembled on torsade (twisted)(1000M)
  Cables medium voltage (19/33 kV) according to the french standard NF C 33 223  or NF C 33 226:
  1. 3x1x240 mm2 assembled on torsade (twisted)(1000M)
  2. 1x630 mm2 (1000M)
argon arc welding - 氩弧焊 (0) 投诉
P:2010-03-02 11:49:50
也太多了。。。。
留给楼下吧
tuner roll - 张力调节轮(拉线机的) (0) 投诉
P:2010-03-02 14:05:57
百度找在线翻译翻下再自己整理下就好了啊
cablemaker - 电缆制造厂 (0) 投诉
P:2010-03-02 15:01:06
这个简单呀
incuction type undervoltage relay - 感应式低压继电器 (0) 投诉
P:2010-03-02 15:13:06
能给我答案不
Kapton insulating/sintering line - 卡普顿聚酰亚胺薄膜绝缘一烧结生产线 (0) 投诉
P:2010-03-02 16:31:49
一半是数字啊,简单的
video - 电视(的,信号),视频(的,信号) (0) 投诉
P:2010-03-03 08:58:37
calking - (电缆)堵头;填隙 (0) 投诉
P:2010-03-04 10:03:12
主要是让你们报最优惠价格
一种是电压1000V
1~7主要都是Al导体的埋地或架空线,都要符合相关的法国标准;
另一种是中压电缆12/20 kV,也是铝导体,符合相应法标;
最后一种是中压电缆12/20 kV,符合相应法标;
shaping roll - 成型轧辊 (0) 投诉
P:2010-04-23 11:22:37
请发送一份高质量下述电缆的合理报价
Cables low voltage (U1000) 低压电缆(1千伏): 2x16 mm2 Alu arial according to the french standard NF C 33 209(7000meter) 2*16平方铝导体架空电缆7000米:按照法国标准:标准号:NF C 33 209 4x16 mm2 Alu underground according to the french standard NF C 33 210(5000M) 4*16平方铝导体敷设电缆 5000米,标准号:NF C 33 210 4x50 mm2 Alu underground  armed according to the french standard NF C 33 210(2000M) 4*50平方平方铝导体敷设铠装电缆2000米, 标准号: NF C 33 210 3x95 + 50 mm2 Alu underground  armed according to the french standard NF C 33 210(1500M) 3*95+50平方平方铝导体敷设铠装电缆1500米,标准号: NF C 33 210 3x150+70 mm2 Alu underground  armed according to the french standard NF C 33 210(1000M) 3*150+95平方平方铝导体敷设铠装电缆1500米,标准号: NF C 33 210 3x240+95 mm2 Alu underground  armed according to the french standard NF C 33 210(1000M) 3*240+95平方平方铝导体敷设铠装电缆1500米,标准号: NF C 33 210 1x240 mm2 Alu ARO2V(1000M)1*240平方铝芯导体外加铠装1000米
中压电压12/20kV,标准号:NF C 33 223  或者NF C 33 226
1x50 mm2(1000M) 1*50平方,1000米 3x1x150 mm2 assembled on torsade (twisted)(1500M) 3*1*150平方绞合带条装配电缆,1500米 3x1x240 mm2 assembled on torsade (twisted)(1000M)3*1*240平方绞合带条装配电缆,1000米   Cables medium voltage (19/33 kV) according to the french standard NF C 33 223  or NF C 33 226:
中压电压(19/33 kV),标准号:NF C 33 223  或者NF C 33 226
3x1x240 mm2 assembled on torsade (twisted)(1000M) 3*1*240平方绞合带条装配电缆,1000米 1x630 mm2 (1000M)1*630平方,1000米
Crawl - 爬,爬行 (0) 投诉
P:2010-04-28 09:14:52
强强强
molded joint - 模制式接头,模塑式接头 (0) 投诉
P:2010-05-06 13:35:27
頂頂頂
full automatic dual-head braider - 全自动双头编织机 (0) 投诉
P:2010-05-28 12:00:34
oh my god, i'm learning..........
encapsulated ribbon structure - 松套带状光纤结构,封装式光纤带结构 (0) 投诉
P:2010-08-31 09:26:44
翻的那是相当专业,好
bowl calender - 辊筒(辗页机的);纱碗(纱包机的) (0) 投诉
P:2010-08-31 14:46:04
就是想要最好的质量、最低的价格而已!
ultrasonic drawing die drilling machine - 超声波拉丝模打孔机 (0) 投诉
