首页 > 汽车线缆
[充电桩缆] 电动汽车充电电缆
P:2010-09-24 18:40:45
<DIV class=xxxxAd><SCRIPT type=text/javascript></SCRIPT><SCRIPT type=text/javascript src="http://pagead2.googlesyndication.com/pagead/show_ads.js"></SCRIPT><SCRIPT>google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);</SCRIPT></DIV>充电电动车及混合动力汽车和设备推出散装电缆,完整的电缆解决方案。 UL所认可并且与SAE J1772连接器,UL 2594和NEC 625充电系统兼容。所有电动电缆有可供选择标准或自定义配置。定制包括混合动力的设计,颜色,个性化标志等等 电动车电缆解决方案包括600V EVE (TPE)和600V EVT (PVC)电缆,可实现从2 AWG到18 AWG,以及300V EVJE (TPE)和300V EVJT (PVC)电缆,可实现从12 AWG到18 AWG。标准护套材料都是规定材料或PVC与尼龙的混合。这些电缆可能包含混合数据,信号和任何型号的AWG通讯。所有材料都通过无铅认证,以确保在潮湿环境下的电动车充电站的使用。
Type EVJ — Rated 300 V, contains two to six 18-12 AWG thermoset-insulated circuit conductors, and may employ one or more insulated grounding conductors. The cable may contain hybrid data, signal, communications, and/or optical fiber cable in any AWG size.
Type EVJE — Rated 300 V, same as Type EVJ except that the cable employs thermoplastic-elastomer-insulated conductors and jacket.
Type EVJT — Rated 300 V, same as Type EVJ except that the cable employs thermoplastic (PVC) insulated conductors.
Type EV — Rated 600 V, contains two or more 18 AWG to 500 kcmil thermoset-insulated circuit conductors, and may employ one or more insulated grounding conductors. The cable may contain hybrid data, signal, communications, and/or optical fiber cable in any AWG size.
Type EVE — Rated 600 V, same as Type EV except that the cable employs thermoplastic-elastomer-insulated conductors.
Type EVT — Rated 600 V, same as Type EV except that the cable employs thermoplastic (PVC) .
Thanks & Best Regards, Project Sales Manager Angus.xian Cell phone:0086-013829165726 MSN:angus.xian@hotmail.com Skype: angus.xianhigh-fidelity audio system - 高保真音频系统 (0) 投诉
