首页 > 型号析疑 产品报价
[问题求助] RG,JIS物理发泡同轴电缆中的RG-59/3C-2V是什么意思
P:2010-04-13 11:29:13
描述如下:
RG coaxial cable descriptionRG – 59 A/ U(1) (2) (3) (4) (1):Radio frequency coaxial cable general purpose(2):Serial number(3):Revision number (alphabetical order)(4):For general purpose application. JIS coaxial cable description3 C – 2 V(1) (2) (3) (4) (1):Insulation diameter(2):Impedence code C:75Ω D:50Ω(3):Insulation code 2:solid PE insulation(4):Optional code (outer conductor jacket etc.) V:single braid,PVC jacket W:double braid,PVC jacket T:triple braid,PVC jacket S:for SP type connector CS:copper clad steel wire inner conductor
songfeiX 奖励 10 金币,5 声望,于 2019-04-08 19:27:14 原因:奖罚
inclinedplane liquid-contami’nant test - 斜板液体污染物试验法,简称斜板法(绝缘材料耐电痕性的一种试验方法) (0) 投诉
