首页 > 型号析疑 产品报价
[型号解析] 求助1672AWG22电缆名字解释,1672代表什么
P:2010-01-15 17:02:55
下表可以在UL电子线网站上下载,UL1672的相关参数表里面有。
AWG22的直径是0.6438mm,圆密耳为645cmil.
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL Subj. 758 Section 1 Page 1672 Issued:1975-10-24 Revised: 2003-03-06 Style 1672 Insulated Wire. ______________________________________________________________________________ Rating 105°C, 300 Volts. ______________________________________________________________________________ Insulated Labeled or complying with manufacturer's AWM Procedure Singles having a minimum rating of 105°C, 300 V. ______________________________________________________________________________ Covering PVC:From 5 to 40 mils may be irradiated. ______________________________________________________________________________ Standard Appliance Wiring Material UL 758. ______________________________________________________________________________ Instructions Detailed Examination. to UL The designation of the style used as the insulated single Representative shall be available and the UL Representative’s tag shall indicate if the style is labeled. If the single is not labeled, the appropriate follow-up tests shall be conducted. ______________________________________________________________________________ UL (4) Detailed Examination. *Counter-Check (12) Horizontal Flame Test. Program If the insulated single is not labeled, the appropriate follow-up tests shall be conducted. ______________________________________________________________________________ Marking General. ______________________________________________________________________________ Use Internal Wiring of Electronic Equipment.spent acid recovery system - 废酸回收系统 (0) 投诉
