首页 > 新产品 新技术
[阻燃耐火] 各国耐火测试
P:2010-01-14 14:44:58
英国耐火标准 British Fire Resistance StandardBS 476-22/20: Fire tests on building materials and structures-part 22/20: Methods for determination of the fire resistance of non-loadbearing elements of construction BS 476-24: Fire tests on building materials and structures-part 24:Method for determination of the fire resistance of ventilation ducts 欧盟耐火标准 EU Fire Resistance StandardEN 13501-2: Fire classification of construction products and building elements. Part 2: Classification using data from fire resistance tests, excluding ventilation servicesEN 1634-1: Fire resistance tests for door and shutter assemblies. Fire doors and shutters美国耐火标准 USA Fire Resistance StandardASTM E 119 Standard Test Method for Fire Tests of Building Construction and Materials国际耐火标准 Internal Fire Resistance StandardISO 834 Fire-resistance tests - Elements of building construction中国耐火标准 GB Fire Resistance StandardGB/T 9978 Fire resistance tests-Elements of building construction
log - 测井(曲线图);记录,记录表 (0) 投诉
