首页 > 国外线缆
[问题求助] 请问XLPE/FRPE认证料哪家好?
P:2010-01-13 14:42:05
请问XLPE 150度 FRPE 认证料哪家好?
sparktester - 火花检验器,干试机 (0) 投诉
P:2010-01-13 17:17:41
你家公司在哪裡?
qualification verification test - 合格鉴定验证试验 (0) 投诉
P:2010-01-13 22:04:24
要认证什么?线规、厚度,只是温度等级,还不能告诉你能否通过
ductile superconducting filamentry alloy - 延性超导合金丝 (0) 投诉
P:2010-01-14 09:11:34
太感谢您们了!我公司在东莞,
(1) #1 XLPE insulated single, rated 150C, 600V, 200 feet
(1) #2 Solid PE insulated single, rated 80C, 300V, 200 feet
(1) #3 Solid PE flat cable (construction as insulation extruded simultaneously over 2 or more conductors), rated 80C, 300V, 200 feet
(1) #4 Solid PP insulated single, rated 60C, 150V, 200 feet
(1) #5 Solid FRPE jackted cable with XLPE insulated conductor(s), unshielded, rated 80C, 300V, 100 feet
(1) # 6 Solid FRPE jacketed cable with XLPE insulated conductor(s), shielded, rated 300V, 50 feet
(1) #7 Solid PVC jacketed cable with Solid PE insulated single (same as sample #2), unshielded, 80C, 50 feet
(1) #8 Solid PVC jacketed cable with Solid PP insulated single (same as sample #4), unshielded, 60C, 100 feet
20AWG就行
HEPR - high molecular ethylene-propylene高分子乙丙烯橡胶 (0) 投诉
P:2010-01-16 10:39:59
请问谁可帮到我?
TEE joint - T型接头 (0) 投诉
P:2010-01-16 15:19:27
我可以帮到你,你加联系方式给我
drum cabling machine - 盘式成缆机 (0) 投诉
P:2010-01-16 15:30:12
anti-buckling member - 抗弯折元件(光缆的) (0) 投诉
P:2010-01-16 15:34:30
我的贸易通:ZYYQ67
tandem colour tape pay-off - 串列式色带放送装置(标志器的) (0) 投诉
P:2010-01-16 16:51:00
XLPE照射交連PE ,UL安規最高125C  非150C也
PE 本身有交連作用,經過電子照射後叫XLPE,所以市面上沒有賣XLPE的,只有HDPE
而FRPE是耐燃PE,要好的料一般都找國外
optical coupler - 光耦合器 (0) 投诉
P:2010-01-19 16:40:03
SKCHANG:
多谢!国外哪家料好?
double sheath - 双护套 (0) 投诉
P:2010-02-20 19:35:05
多谢!国外哪家料好呀?
mono-crystalline diamond wire drawing die - 单晶金刚石拉线模 (0) 投诉
P:2010-02-26 15:21:47
刚看题目以为楼主要一种阻燃105度的交联聚乙烯材料。拉出明细才看出来是询问两种料:1. FRPE护套料;2.XLPE绝缘材料,耐温105度。这个国内材料厂家可以有啊
beam - 射束,光束,电子束 (0) 投诉
P:2010-02-27 10:16:14
SKCHANG:
XLPE照射交連PE ,UL安規最高150C,并非125C
galvanizing bath - 电镀槽,镀锌槽,锌浴 (0) 投诉
