首页 > 矿用橡套电缆
[问题求助] WYH型电缆参照什么标准
P:2010-01-12 08:32:45
WYH型电缆的绝缘、护套厚度及检查参照什么标准?
corrugated metal tape - 皱纹金属带 (0) 投诉
P:2010-01-12 09:07:56
是德标的要求吧
Pl - power input功率输入 (0) 投诉
P:2010-01-12 10:08:08
客户要求多少啊
ARPASP - aluminium resinbonded polyethylene aluminium steel polyethylene铝-树脂粘接剂-聚乙烯-铝-钢-聚乙烯(电缆综合护层) (0) 投诉
P:2010-01-12 19:52:34
不清楚
Okolon insulated Okonite - 奥科龙绝缘护套(美国Okonite公司研制的一种氯磺化聚乙烯绝缘护套) (0) 投诉
P:2010-01-16 17:09:41
本产品采用企业标准及参照英国标准BS5308,同时还可根据用户需要按国际电工委员会推荐标准IEC、英国标准、德国标准及美国标准生产各种型号的电缆的数据及重量
<DIV align=left>★用途:本产品供交流额定电压500V及以下的野外条件下半移动装置使用。</DIV>
<DIV align=left>★使用条件:环境温度为-45℃~+50℃,线芯长期允许工作温度在应不超过+65℃。</DIV>
<DIV align=left>★型号.名称:见表</DIV>
<DIV align=left>★规格尺寸.重量及技术参数:</DIV>
<DIV align=left>
<DIV align=center>型号</DIV><DIV align=center>芯数×标称截面(mm2)</DIV><DIV align=center>电缆外径(mm)</DIV><DIV align=center>电缆重量(kg/km)</DIV>
<DIV align=center></DIV><DIV align=center>WYH</DIV><DIV align=center>7×0.8</DIV><DIV align=center>12.9</DIV><DIV align=center>206</DIV>
<DIV align=center>10×0.8</DIV><DIV align=center>6.7</DIV><DIV align=center>315</DIV>
<DIV align=center>12×0.8</DIV><DIV align=center>17.1</DIV><DIV align=center>351</DIV>
<DIV align=center>14×0.8</DIV><DIV align=center>17.8</DIV><DIV align=center>393</DIV>
<DIV align=center>16×0.8</DIV><DIV align=center>18.6</DIV><DIV align=center>435</DIV>
<DIV align=center>19×0.8</DIV><DIV align=center>19.5</DIV><DIV align=center>485</DIV>
<DIV align=center>24×0.8</DIV><DIV align=center>22.2</DIV><DIV align=center>601</DIV>
<DIV align=center>27×0.8</DIV><DIV align=center>22.7</DIV><DIV align=center>653</DIV>
<DIV align=center>30×0.8</DIV><DIV align=center>23.4</DIV><DIV align=center>711</DIV>
<DIV align=center>33×0.8</DIV><DIV align=center>24.2</DIV><DIV align=center>769</DIV>
<DIV align=center>37×0.8</DIV><DIV align=center>25.0</DIV><DIV align=center>836</DIV>
<DIV align=center>44×0.8</DIV><DIV align=center>27.8</DIV><DIV align=center>983</DIV>
<DIV align=center>48×0.8</DIV><DIV align=center>28.2</DIV><DIV align=center>1051</DIV>
</DIV>
<DIV align=center>★野外橡皮绝缘电力电缆(企业标准)</DIV>
<DIV align=left>★用途:适用于交流电压500V或直流1000V及以下野外条件使用,作移动式电气设备连接电缆。</DIV>
<DIV align=left>★使用条件:环境温度为-45℃~+50℃,电缆线芯间的长期允许工作温度+65℃。</DIV>
<DIV align=left>★型号、规格尺寸及技术参数:</DIV>
(mm2) </DIV>
<DIV align=center>导线线芯根数/单线
标称直径线径(mm) </DIV>
<DIV align=center>绝缘标称厚度
(mm)</DIV>
<DIV align=center>护套标称厚度
(mm) </DIV>
<DIV align=center>电缆最大外径
(mm)</DIV>
<DIV align=center>20℃导体直流
电阻≤(Ω/km) </DIV>
<DIV align=center>YHD</DIV><DIV align=center>2×1.0</DIV><DIV align=center>32/0.20</DIV><DIV align=center>0.9</DIV><DIV align=center>1.4</DIV><DIV align=center>10.6</DIV><DIV align=center>20.0</DIV>
<DIV align=center>2×1.5</DIV><DIV align=center>30/0.25</DIV><DIV align=center>0.9</DIV><DIV align=center>1.4</DIV><DIV align=center>11.2</DIV><DIV align=center>13.7</DIV>
<DIV align=center>2×2.5</DIV><DIV align=center>49/0.25</DIV><DIV align=center>0.9</DIV><DIV align=center>1.4</DIV><DIV align=center>12.9</DIV><DIV align=center>8.21</DIV>
<DIV align=center>2×4</DIV><DIV align=center>56/0.30</DIV><DIV align=center>0.9</DIV><DIV align=center>1.4</DIV><DIV align=center>14.1</DIV><DIV align=center>5.09</DIV>
<DIV align=center>2×6</DIV><DIV align=center>84/0.30</DIV><DIV align=center>0.9</DIV><DIV align=center>2.3</DIV><DIV align=center>17.6</DIV><DIV align=center>3.39</DIV>
<DIV align=center>2×10</DIV><DIV align=center>84/0.40</DIV><DIV align=center>1.1</DIV><DIV align=center>2.8</DIV><DIV align=center>22.2</DIV><DIV align=center>1.95</DIV>
<DIV align=center>2×16</DIV><DIV align=center>126/0.40</DIV><DIV align=center>1.1</DIV><DIV align=center>3.3</DIV><DIV align=center>26.4</DIV><DIV align=center>1.24</DIV>
<DIV align=center>2×25</DIV><DIV align=center>196/0.40</DIV><DIV align=center>1.3</DIV><DIV align=center>4.3</DIV><DIV align=center>32.2</DIV><DIV align=center>0.795</DIV>
<DIV align=center>3×1.0</DIV><DIV align=center>32/0.20</DIV><DIV align=center>0.9</DIV><DIV align=center>1.4</DIV><DIV align=center>11.1</DIV><DIV align=center>20.0</DIV>
<DIV align=center>3×1.5</DIV><DIV align=center>30/0.25</DIV><DIV align=center>0.9</DIV><DIV align=center>1.4</DIV><DIV align=center>11.9</DIV><DIV align=center>13.7</DIV>
<DIV align=center>2×2.5</DIV><DIV align=center>49/0.25</DIV><DIV align=center>0.9</DIV><DIV align=center>1.4</DIV><DIV align=center>13.7</DIV><DIV align=center>8.21</DIV>
<DIV align=center>3×4</DIV><DIV align=center>56/0.30</DIV><DIV align=center>0.9</DIV><DIV align=center>2.3</DIV><DIV align=center>17.1</DIV><DIV align=center>5.09</DIV>
<DIV></DIV><DIV></DIV><DIV></DIV>
[liu730320 在 2010-1-16 17:11:36 编辑过]
VIT - very intelligent terminal高智能终端 (0) 投诉
P:2010-01-18 09:28:17
这几个字母代表什么含义啊
radio frequency - 射频,无线电频率,高频 (0) 投诉
