首页 > 连接器 插头附件
[问题求助] 求ANSI-EIA-364标准(提供奖励金币积分20,还有金币)
P:2010-01-11 21:17:04
先传一部分
老大,你级别太高加不了。。非常感谢。
[zhengliang 在 2010-1-12 8:34:51 编辑过]
ANSI/EIA-364-01B-2000 Acceleration Test Procedure for Electrical Connectors.pdf
ANSI/EIA-364-03B-1999(R2006) Altitude Immersion Test Procedure For Electrical Connectors.pdf
ANSI/EIA-364-03C-2009 ALTITUDE IMMERSION TEST ALTITUDE IMMERSION TEST.rar
ANSI/EIA-364-06B-2000 Contact Resistance Test Procedure for Electrical Connectors.pdf
ANSI/EIA-364-06C-2006 CONTACT RESISTANCE TEST PROCEDURE FOR ELECTRICAL CONNECTORS.pdf
ANSI/EIA-364-07C-2007 CONTACT AXIAL CONCENTRICITY TEST PROCEDURE FOR ELECTRICAL CONNECTORS.pdf
ANSI/EIA-364-09C-1999 Durability Test Procedure for Electrical Connectors and Contacts.pdf
cable vulcanizer - 电缆硫化器 (0) 投诉
P:2010-01-11 21:20:57
flexographic inking system - 胶印油罨印字系统 (0) 投诉
P:2010-01-11 21:23:54
ANSI/EIA-364-56D-2008 RESISTANCE TO SOLDERING HEAT TEST PROCEDURE FOR ELECTRICAL CONNECTORS AND.pdf
EIA-364-78 电子连接器插座结合整体漏气测试程序.pdf
ANSI/EIA-364-87A-2009 NANOSECOND EVENT DETECTION TEST PROCEDURE FOR.rar
ANSI/EIA-364-105-A-2008 ALTITUDE – LOW TEMPERATURE TEST PROCEDURE FORELECTRICAL CONNECTORS AND.pdf
ANSI/EIA-364-07B-1998 Contact Axial Concentricity Test Procedure for Electrical Connectors.pdf
