首页 > 型号析疑 产品报价
[型号解析] UL3320 和 UL3122 有什么区别?
P:2009-12-30 19:26:16
请问高手们UL3320 和 UL3122 有什么区别?谢谢!急!
message transmission - 信息传输 (0) 投诉
P:2009-12-30 19:28:06
在线待!!
triplexed cureprene insulated cable - 三芯交联聚乙烯绝缘电缆 (0) 投诉
P:2009-12-30 19:38:20
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 3 Page 3320 Issued: May 10, 1977
Revised: March 9, 2001
*Style 3320 Cross-Linked Synthetic Polymer Insulated Wire
______________________________________________________________________________
Rating 90°C, 600 Volts
Conductor No. 30-2 AWG, inclusive, tinned or untinned solid or
stranded copper. Splices same as required
for rubber-insulated wire.
Insulation Conductor Size Min Avg. Min at any point
AWG (Mils) (Mils)
______________ ________ ________________
30 - 9 30 mils 27 mils
8 45 mils 41 mils
7 - 2 60 mils 54 mils
Chemically cross-linked thermosetting polyethylene. See
Facing Page for compound identification or Type XHHW
compound per the latest bulletin.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination
to UL Tensile strength and elongation of insulation, same as for
Representative Class XL UL 44 unaged.
See Facing Page if not specified.
Spark Test.
18 - 16 AWG - 6000 Volts
14 - 9 AWG - 7500 Volts
8 - 2 AWG - 10,000 Volts
UL (4) Detailed Examination
Counter-Check (4) Tensile strength and elongation of insulation, same as
Program for Class XL, unaged and after aging - UL 44.
(4) Heat Shock, at 136°C.
(4) Deformation, T-2/T-1 equals 0.70.
(4) Cold Bend
(4) Horizontal Flame Test
(Continued on Page 3320A)
dual aluminium tape pay-off - 双铝带放送装置 (0) 投诉
P:2009-12-30 19:39:49
UNDERWRITERS LABORATORIES, INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 3 Page 3122 Issued: April 22, 1960
Revised: March 7, 2001
Style 3122 Silicone Rubber-Insulated Wire.
Rating 200°C, 300 Volts.
Conductor No. 26-16 AWG, solid or stranded, silver plated, or
nickel coated copper conductor or nickel conductor or
tinned copper (tinned copper strands minimum 15 mils
diameter).
Insulation Nominal 1/64 inch wall Silicone Rubber, Class 22.
Covering Same as for Type SF-1 Fixture Wire.
Standard Appliance Wiring Material, UL 758.
Instructions
to UL
Representative
Same as for type SF-1 Fixture Wire but omit Insulation-
Resistance Test and Vertical Flame Test.
Spark Test.
Horizontal Flame Test.
UL
Counter-Check
*Program
(4) Same as for Type SF-1 Fixture Wire; omit Vertical
Flame Test, aging shall be conducted annually
(4) Horizontal Flame Test.
Marking General.
Use Internal Wiring of Appliances.
double-tape armor - 双带铠装,双钢带铠装 (0) 投诉
P:2009-12-31 07:42:52
UL规定3122是编织硅胶线,很多日资厂要3320编织硅胶线,但UL 好象没规定,你不妨问问日新的人,好象他们有做
Industrial alcohol - 工业酒精 (0) 投诉
