首页 > 国外线缆
[问题求助] HOOK-UP WIRE是什么线
P:2007-03-02 11:44:40
HOOK-UP WIRE是什么线?
PVB - poly(vinyl butyral)聚乙烯基丁醛 (0) 投诉
P:2007-03-02 12:29:07
就是电子线吧!
longitudinal water blocking - 纵向阻水 (0) 投诉
P:2007-03-02 13:49:45
Used extensively for both electrical and electronic equipment, Hook- Up Wires are required to perform in increasingly critical environments.  Cost-effective production methods necessitate uniform wire handling characteristics:  strippability, strand uniformity, precise dimensions, and permanent colors and markings.  Industry trends such as miniaturization, plus new environmental and product liability considerations require improved Insulation materials.
high voltage paper taping machine - 高压纸包机 (0) 投诉
P:2007-03-02 15:34:03
如:1061、1571、1007等
thermostabiJity - 耐热,热稳定,耐热性,热稳定性 (0) 投诉
P:2007-03-04 09:51:10
能否给我来一份wanghaitao@qianlong.com
cable pressure monitoring system - 电缆气压监测系统 (0) 投诉
P:2007-03-04 10:21:32
我确认是电子线
coiling - 成圈 (0) 投诉
P:2007-03-13 17:02:07
就是电子线.
traversing system - 排线装置 (0) 投诉
P:2007-03-13 21:44:41
半硬质PVC电子线,即SR-PVC电子线
SAPI - service access point identitier业务接入点识别符 (0) 投诉
P:2007-03-19 20:20:54
用英文来解释是:A wire used for low current, low voltage (under 1000 volts) applications within enclosed electronic equipment.
用中文来解释是:用于电子设备中的低电流低压(小于1000V)的电线.
fiber-glass braided wire - 玻璃丝编织线 (0) 投诉
P:2007-03-20 11:07:40
是低压电子线
recovery - (冷轧后的)消除应力退火;回收,(废物)利用,废物利用 (0) 投诉
P:2007-03-21 11:33:50
就是電子連接線,UL都這麼說!!!!
diameter control chute - 直径控制电路 (0) 投诉
P:2007-05-05 15:37:11
電子連接線
SILTEM - 西尔提姆(美国通用电气公司研制的一种有机硅-聚酰亚胺共聚物商品名,是一种无卤的高弹性嵌段共聚物材料,适用作电缆绝缘及护套) (0) 投诉
P:2007-05-06 09:03:20
就是低压电子线了!
loadbreak connector - 有载插接头 (0) 投诉
P:2007-06-20 14:47:18
温度范围广,颜色范围广,各仪器设备,家用的电子设备连接用的电子线,
FM - fibrin monomer纤维单体; (0) 投诉
P:2007-06-21 09:48:03
这个就是电子线嘛,认识它十年了!
FMS - fiber management system光纤管理系统 (0) 投诉
22
