首页 > 国外线缆
[问题求助] 谁有 UL2722 的相关资料
P:2009-12-16 18:08:29
谁有 UL2722 的相关资料
thermoplastic-covered wire - 热塑性塑料绝缘线 (0) 投诉
P:2009-12-16 18:08:50
感激不尽啊
cyclic current rating - 周期性额定电流 (0) 投诉
P:2009-12-16 18:29:05
UNDERWRITERS LABORATORIES INC.      APPLIANCE WIRING MATERIAL
Subject 758   Section 1   Page 2722     Issued: March 7, 1959
  Style 2722        Braidless Parallel Lead Wire
  Rating            105 C, 300 Volts
  Conductors        Two, three or four Nos. 18-26 AWG tinned or
                    bare copper, page 26.
  Integral          Similar to SPT except using Class 12 insulation
  Insulation        1/64 inch thick and shall maintain minimum 0.013
  and Jacket        inch of thickness after ripping at the web.
  Standard          Flexible Cord and Fixture Wire
  Instructions      Detailed examination.
     to             Tensile strength and elongation of insulation,
  Inspector           same as for Class 12, page 32.
                    Spark Test, page 30.
  Northbrook        (4) Detailed examination.
  Counter-Check     (4) Tensile strength and elongation of insulation,
  Program               same as for Class 12, page 33.
                    (4) Heat Shock, page 37.
                    (4) Deformation, page 38.
                    (4) Cold Bend, page 39.
  Marking           General, page 13.
  Use               Internal wiring of electronic equipment.
                    Tags may indicate the following:
                     "600 Volts Peak - For Electronic Use Only"
die repolishing - 线模再抛光 (0) 投诉
