[技术资料] IEEE 1394a RAW CABLE 测试标准,同行沟通下是否正确?TKS!
P:2009-12-10 09:25:27
IEEE 1394a RAW CABLE 测试标准如下:同行看下是否正确?
Differential Impedance: 110+/-6 ohm
Common Impedance: 33+/-6 ohm
Fext: -26dB(1—75MHz)
Inter pair skew: 400PS/cable
Delay: 5.05ns/m
ATT :-2.3db/cable@100MHz,-3.2db/cable@200MHz,-5.8db/cable@400MHz
如上,若按一般裁线长度 4.5 M 测试,结果若是NG, 换做测试3M, 那ATT 如何换算成3M标准呢?
请同行高手说下,多谢。
to break the batch loose from the rolls - 从滚筒上切下橡条 (0) 投诉
