首页 > 国外线缆
[问题求助] 20276 UL要求AC与DC电压是多少?
P:2009-12-09 09:01:04
sun light - 日光,阳光;太阳灯 (0) 投诉
P:2009-12-09 09:45:57
UL20276,作低电压音频\视频线使用,如HDMI、电脑周边。。。
电压值为30V
hood type annealing furnace - 钟罩式退火炉 (0) 投诉
P:2009-12-09 10:14:55
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 20276       Issued:  1983-08-16
                                    Revised:  2003-06-05
Style 20276     Electronic Cable.
______________________________________________________________________________
Rating      60°C or 80°C, 30 V.
Insulated       No. 40 AWG minimum.  Labeled or complying with AWM
Conductors      Procedure having a minimum rating of 60°C or 80°C
            whichever is applicable.
Assembly        Consists of two or more conductors, twisted pairs,
            parallel pairs, or groups of twisted conductors or
            parallel pairs twisted together.  The conductors or
            groups of conductors may be laid parallel forming a flat,
            oval or round cable.  The lay of the insulated conductors
            are not specified.  A barrier layer and/or fillers are
            optional.  Manufacturer shall maintain a complete
            description of each assembly.  May use same or mixed AWG
            size.
Covering        (Optional.)  A 6 mil or heavier PVC covering may be
            extruded over the conductor assembly.
Shield      Optional.
Jacket      PVC, Class 43.
                Thickness (mils)
                  Construction A       Construction B
                External Use         Internal Use
            #Dia. under                Minimum            Minimum
             jacket in         Minimum      at       Minimum      at
              inches__       Average   any Point   Average   any Point
            0.350 or less       20        17         15         12
            0.351 - 0.700       30        24         30         24
            0.701 - 1.00        40        36         40         36
            0.101 - 1.50        54        48         54         48
Standard        Appliance Wiring Material UL 758.
                                (Continued on Page 20276A)
Subj. 758       Section 2       Page 20276A      Issued:  1983-08-16
                                    Revised:  2003-06-05
Instructions    Detailed Examination.
to UL           Physical Properties of Jacket.
Representative
            The designation of all Styles of the individual
conductors used making up the cable assembly shall be
available, and the UL Representative's tag shall indicate
if the Style is labeled or not.  If they are not labeled,
the appropriate Follow-Up Tests shall be conducted.
UL          (4)  Detailed Examination.
*Counter-Check  (4)  Physical Properties of Jacket.
*Program        (4)  Heat Shock.
*           (4)  Cold Bend.
*           (4)  Deformation.
            (12) Cable Flame Test on Completed Cable,
                 Construction A only.
            (12) Horizontal Flame Test on Completed Cable,
                 Construction B only.
            If the insulated Styles are not labeled, the appropriate
Marking     General.
Use         Construction A:  Internal wiring or external
            interconnection of electronic equipment in Class 2
            circuits only.
            Construction B:  Internal wiring of electronic equipment
            in Class 2 circuits only.
dimension - 尺寸,大小,规格 (0) 投诉
