首页 > 标准共享
[国外标准] ASTM D 1043-99 Standard Test Method for Stiffness Properties of Plastics as a Function of Temperature by Means of a Torsion Test
P:2009-12-08 16:11:36
ASTM D 1043-99 Standard Test Method for Stiffness Properties of Plastics as a Function of Temperature by Means of a Torsion Test.pdf
SwRl - Southwest Research Institute(美国)西南研究所 (0) 投诉
P:2009-12-08 19:00:06
ASTM D 1043-02 Standard Test Method for Stiffness Properties of Plastics as a Function of Temperature by Means of a Torsion Test.pdf
WRCA - Wire Rope Corporation ofAmerica美国缆索公司 (0) 投诉
