首页 > 标准共享
[国外标准] ASTM D 743 790 标准全集 继续
P:2009-11-26 15:25:35
努力的下吧大家
ASTM D 743-02 Standard Test Method for Shear Strength of Plastics by Punch Tool.pdf
ASTM D 743-99X Standard Test Method for Shear Strength of Plastics by Punch Tool.pdf
ASTM D 743-99 Standard Test Method for Shear Strength of Plastics by Punch Tool.pdf
ASTM D 746-04 Standard Test Method for Brittleness Temperature of Plastics and Elastomers by Impact.pdf
ASTM D 746-98X Standard Test Method for Brittleness Temperature of Plastics and Elastomers by Impact.pdf
ASTM D 746-98 Standard Test Method for Brittleness Temperature of Plastics and Elastomers by Impact.pdf
ASTM D 747-02 Standard Test Method for Apparent Bending Modulus of Plastics by Means of a Cantilever Beam.pdf
ASTM D 747-99 Standard Test Method for Apparent Bending Modulus of Plastics by Means of a Cantilever Beam.pdf
ASTM D 785-03 Standard Test Method for Rockwell Hardness of Plastics and Electrical Insulating Materials.pdf
ASTM D 785-98 Standard Test Method for Rockwell Hardness of Plastics and Electrical Insulating Materials.pdf
ASTM D 787-96 Standard Specification for Ethyl Cellulose Molding and Extrusion Compounds.pdf
ASTM D 789-96 ASTM D 789-98 Standard Test Methods for Determination of Relative Viscosity and Moisture Content of Polyamide (PA).pdf
ASTM D 790-00 Standard Test Methods for Flexural Properties of Unreinforced and Reinforced Plastics and Electrical Insulating Materials.pdf
ASTM D 790-03 Standard Test Methods for Flexural Properties of Unreinforced and Reinforced Plastics and Electrical Insulating Materials.pdf
additional channel - 增补频道(有线电视) (0) 投诉
P:2009-11-26 16:01:56
想赚金币呀!
skeleton layout - 草图,简图 (0) 投诉
P:2009-11-26 18:53:02
能不能少要点金币啊
wire rolling technology - 线材轧制工艺 (0) 投诉
P:2009-12-03 12:11:26
可以呀,想要的话可以发邮件给我arroy@mail.com
cable vocabulary - 电缆专业词汇 (0) 投诉
P:2009-12-03 13:42:18
不够金子··
product range - 产品种类,产品系列 (0) 投诉
