[HDMI] 求助HDMI 规范中Standard Speed 和 High Speed的定义与区别?
P:2009-11-24 10:36:30
Standard HDMITM cables are tested to carry a standard HD 720p or 1080i signal.
Category 2 cables should be marked as:“High Speed HDMITM Cable”
The following description should be used to describe the qualities of a High Speed cable:High Speed HDMITM Cables are tested to carry an HD signal up to 1080p and higher. Use a High Speed Cable also for 720p/1080i signals that are capable of increased refresh rates (above 60Hz) or Deep Color. High Speed HDMITM Cables will also support applications that only require a Standard HDMITM Cable.
aluminum core - 铝芯,铝线芯 (0) 投诉
