首页 > 标准共享
[国外标准] UL 2556-2007 Wire and Cable Test Methods
P:2009-11-19 12:54:41
各位大哥:
                  現在急需UL2556,哪位大哥有的幫助一下啊,謝謝各位好人啦 !
         聽UL說:1581和758最終都會被2556取代,現在部份測試標準已經按2556走了,所以急需了解學習,望大家不要吝嗇啊!
vertical-tray flame test - 垂直托架燃烧试验 (0) 投诉
P:2009-11-19 14:29:20
UNDERWRITERS LABORATORIES, INC.               FACTORY INSPECTION PROCEDURE
Subj.  758       Section   2        Page  2556   Issued  December 27, 1971
Vol.          This Page Effective               Revised
  Style 2556    Multi-Conductor Irradiated (Extruded, or Laminated)
                Flame-Retardant Polyethylene Insulated Flat Cable
  Rating        60 C, no voltage assigned.
  Conductors    27 through 60, No. 33 Awg, silver coated solid copper.
  Insulation    Irradiated (extruded, or laminated) flame-retardant
                polyethylene in min. 7 mil wall.  Conductors within
                row separated min. 3 mils.  The adjacent ground
                conductors within a row may touch.  Total over-all
                thickness of cable min. 25 mils.
  Standard      Flexible Cord and Fixture Wire (Subj. No. 62).
  Instructions   Detailed examination.
       to       Dielectric Strength 900 V for 1 min. (1) between
  Inspector      adjacent conductors, (2) between conductors and
                 two metal plates.
                Insulation shall not crack when cable is flexed
                 flatwise into a U-bend around a 1/8 in. diam. mandrel.
  Northbrook    (4) Detailed examination.
  Counter-Check     (4) Cold bend.  Insulation shall not crack when
  Program            cable is flexed into a U-bend around a 1/2
                     in. diam. mandrel and taped into place.  The
                     cable shall be allowed to cool to minus 20 C
                     for one hour.
                (4) Age 168 hours at 100 C and subject to dielectric
                     strength test described above.
                (2) Flame test, Page 31.  One length of cable to be
                     supported flat with flame applied in center of
                     width, and another length of cable held on edge
                     with flame applied on lower edge.
  Marking       General, Page 13.
  Use           For use in protected locations in data
                processing equipment and office appliances.
non-round wire - 非圆线,异形线 (0) 投诉
P:2009-11-19 14:31:37
,我还以为你要是758里的2556呢。。。
cage stranding machine - 笼式绞线机,笼绞机 (0) 投诉
P:2009-11-19 14:37:11
楼主可以到下面的帖子中进行下载:
不过好贵呀?
楼主的威望也不够!需要60个金币!
http://www.dxdlw.com/ShowPost.asp?PageIndex=2&ThreadID=31374
number transfer bus - 数值传输线 (0) 投诉
P:2009-11-20 12:25:02
不知道是不是最新版的哦!我才來的,以後多多關照啊
all-metal folding steel reel - 全金属折叠式钢制线盘 (0) 投诉
P:2009-11-20 15:19:32
最新版本的就是07版的吧!
反正我用的就是07版的!
slide wire - 滑触线 (0) 投诉
P:2009-12-10 15:46:01
planishing - 精轧 (0) 投诉
P:2009-12-10 19:46:01
谢谢你了,好人.
cover wire - 外层线,外层钢丝 (0) 投诉
P:2009-12-15 15:04:35
 谢谢 youxia3185
profile - 剖面,断面,分布;剖面图,断面图,分布图;型材;胶料;(橡胶的机械物理)性能 (0) 投诉
P:2009-12-18 20:41:40
赚到钱我就买...
DCS - digital cross-connect system数字跨接系统 (0) 投诉
P:2009-12-21 11:21:03
谢谢!
emulsion - 乳浊液(拉线,压延时用),乳化液 (0) 投诉
