首页 > 特种电缆
[问题求助] 请教各位同行:AWM3239 FEP 150℃ 10KV、20KV、30KV的绝缘厚度分别多少合适?
P:2009-11-16 20:57:17
AWM3239 FEP 150℃ 10KV、20KV、30KV高压线的绝缘厚度分别多少合适?我司现在在申请这款线的UL认证,但不知绝缘厚度做到多少最为合适,还望各位大侠帮忙解答,不胜感激!
waveform - 波形 (0) 投诉
P:2009-11-17 08:02:34
怎么没人回答呢?难道大家都没生产过这种高压线?
prime conductor - 主导线,主导体,(静电学中的)导体 (0) 投诉
P:2009-11-17 09:10:01
标准里面肯定写的很详细。你还是吧标准读熟点吧
channel bundle cable - 通道光缆束,通道信道光缆束 (0) 投诉
P:2009-11-17 10:10:51
标准见下面,就是没有明确的厚度要求, 那个facing page找不到,真是郁闷!
UNDERWRITERS LABORATORIESAPPLIANCE WIRING MATERIAL
Subj.758Section 3Page 3239Issued:1969-10-13
Revised:2009-02-17
Style 3239High-Voltage Lead Wire
RatingMaximum 200 deg C, 60000 Vdc, VW-1 flame. See facing page for temperature and voltage ratings.
Conductor24-10 AWG copper or nickel and 12-10 AWG aluminum or 27-20 AWG Resistance Wire; solid or stranded. Or 24-10 AWG solid or stranded coated high strength copper - min 90% conductivity. Aluminum conductors shall be permitted for a 90 deg C maximum operating temperature. Copper conductors may be tinned, silver or nickel plated, heat bonded or overcoated.
InsulationThermoplastic and/or Thermosetting. See facing page for details.
ShieldSee facing page for details.
CoveringSee facing page for details.
JacketSee facing page for details.
StandardAppliance Wiring Material UL 758.
MarkingIf the outer surface of the wire is PVC, XLPVC, PVDF, PE, XLPE, XLPO, or glass or cotton braid, the wire shall be surface printed. Surface printing on other materials is optional unless otherwise noted on the facing page. 1. Recognized's Company's name or E number. 2. Plant identification, if made in more than one location. 3. DC voltage rating. 4. Temperature rating, if above 60 deg C. 5. Style No. 3239. 6. The Recognized Component Mark followed by the letters AWM or the words, Appliance Wiring Material. 7. (Optional) VW-1.
UseInternal wiring of TV receivers or where the acceptability has been determined by Underwriters Laboratories.
integrated communication system - 综合通信系统 (0) 投诉
P:2009-12-15 10:25:12
10KV  1.0
20KV  1.3
30KV  1.7
dielectric breakdown - 介质击穿,电介质击穿 (0) 投诉
P:2009-12-15 17:12:18
谢谢5楼的朋友,请问这个数值是贵公司自定的常规厚度吗?有没有标准支持?
dieholder - 模架,模座 (0) 投诉
P:2010-03-03 13:19:02
10KV  1.0
20KV  1.3
30KV  1.7
不是吧
finite element method - 有限元素法 (0) 投诉
P:2010-09-02 11:03:03
这个厚度自己定,没有标准,各家都不同的。
screened installation wire - 屏蔽安装线 (0) 投诉
