首页 > 国外线缆
[问题求助] UL 2646 26AWG 芯线集合要求的绞距是多少?
P:2009-11-05 08:23:58
 导体:18/0.1  符合UL标准26AWG的要求吗?
UL2646 26AWG 芯线集合要求的绞距是多少?
dynamically balanced collapsible spool - 动力平衡式可折叠线盘 (0) 投诉
P:2009-11-05 14:59:02
符合,芯线集合一般没有要求!
FTTD - fiber-to-the-desk光纤到桌面 (0) 投诉
P:2009-11-07 22:21:51
芯线集合j是什么意思啊?
H.T.s. - high-tension supply高压电源 (0) 投诉
P:2009-11-09 23:03:14
wolfman:
符合,芯线集合一般没有要求!
也是有要求的
wire processing plant - 线材加工设备 (0) 投诉
P:2009-11-10 08:38:20
LUORI:
也是有要求的
绞距有什么要求??
characteristic curve - 特性曲线 (0) 投诉
P:2009-11-10 10:58:48
集合绞距要求在哪个标准里?哪节哪章?
GIP - Georgia International Plaza(美)佐治亚国际市场 (0) 投诉
P:2009-11-10 15:30:15
UL758 1581上都能找到,去找吧
oxygen - 氧 (0) 投诉
P:2009-11-10 17:54:30
UNDERWRITERS LABORATORIES INC.               APPLIANCE WIRING MATERIAL
Subj. 758       Section 2       Page 2464        Issued:  1968-05-02
                                    Revised:  2003-05-02
Style 2464      PVC Jacketed Cable.
______________________________________________________________________________
Rating      80°C, 300 V.
Insulated       Labeled or complying with manufacturer's AWM Procedure
Conductors      having a minimum rating of 80°C and 300 V.
Assembly        Two or more singles, twisted pairs of groups of twisted
            singles twisted together or singles or groups of singles
            may be laid parallel to form flat, oval or round cable.
            Lay not specified.  Barrier layer and/or fillers optional.
            Manufacturer shall maintain a complete description of each
            assembly.  May use same or mixed AWG size.
*Covering       (Optional.)
Shield      Optional.
Jacket      PVC - Class 43
                         THICKNESS OF PVC JACKET (mils)
            #Dia. of Cable                  Minimum
            Under Jacket        Minimum     at any
               in Inches         Average      point
            0.700 or less          30             24
            0.701 - 1.000          45             36
            1.001 - 1.500          60             48
            1.501 - 2.500          80             64
            2.501 - 4.000         110             88
            4.001 or larger        140           112
            # Major diameter if cable is flat or oval.
Braid           Optional.
Standard        Appliance Wiring Material UL 758.
                                (Continued on Page 2464A)
Subj. 758       Section 2       Page 2464A     Issued:  1968-05-02
                                   Revised:  2003-05-02
Instructions    Detailed Examination of the cable assembly and jacket.
to UL           Physical Properties of Jacket.
Representative  Dielectric Strength Test, 1500 Volts (shielded cable only).
The designation of all Styles of the individual conductors used making up the cable assembly shall be available, and the UL Representative’s tag shall indicate if the Style is labeled or not.  If they are not labeled, the appropriate Follow-Up Tests shall be conducted.
UL          (4)  Detailed Examination.
Counter-Check   (4)  Physical Properties of Jacket.
Program     (4)  Heat Shock on Jacket.
            (4)  Cold Bend on Completed Cable.
            (4)  Deformation on Jacket, Class 43.
            (12) Cable Flame Test on Completed Cable.
If the insulated styles are not labeled, the appropriate Follow-Up Tests shall be conducted.
Marking     General.
Use         Internal wiring or external interconnection of electronic
            equipment (such as desk-type calculators, dictating
            machines, or x-ray equipment).
flipper - 翻锭器;导卫装置,围盘活套机构(轧机的) (0) 投诉
