[供应信息] 大量cable用端子、连接器、磁铁芯、五金件出售,原厂正货,数量有限
P:2009-10-21 11:57:33
原厂:3M, Molex,     JST,   DELPHI,   FCI
sealed metallic moisture barrier - 密封金属隔潮层 (0) 投诉
P:2009-10-21 12:09:42
联系人:Tom
手机:13694281129
邮箱:deyijingmi@163.com
carbide - 碳化物,硬质合金 (0) 投诉
P:2009-10-21 12:36:29
部分料号列表:
3M4634-6300Connector
3M3399-6626IDC Socket
3M3452-7616IDC Socket
3M3414-6634IDC Socket
3M3421-7620IDC Socket
3M4620-6300Connector
3M4610-6350Connector
3M7964-6500ECIDC
AMP5746613-3PLUG
AMP1658686-1CONTACT
AMP641994-1PIN
AMP3-215911-4CONNECTOR
AMP2-215911-6CONNECTOR
AMPAMP#176143-2Connector
AMP292254-4CT-4 PIN PANEL MOUNT
AMP1-747948-5TERMINAL
AMP640714-1Strain relief
AMP292133-3Header
AMP640204-1Ring
AMP292156-2Clip
Da/ProC5956-40920Connector boot
DELPHI15336029CONNECTOR
DELPHI15397275CONNECTOR
FCI65043-032LFCONNECTOR
FCI65307-001LFPOLARIZING KEY
FCI10033998-002Connector
FCI211PL249S0033Conn
JSTSZM-41T-P0.7PIN
JSTZLS-03VRetainer CLIP
JSTVLS-03VRetainer CLIP
JSTVLP-06V-1Socket HOUSING
JSTSVF-61T-P2.0Contact
JWT#A1002H00-8P8P HOUSING
JYCA2544H00-5PHSG
JYCA2501H02-10PHSG.10P
JYCA2501H02-8PHSG
MOLEX HDMI FEMALE SOLDER GOLD 5U"
positronicFC422N7/AA-PA412Contact
positronicFC120N2/AA-PA362Contact
TYUTYU#TU2003TPO-GOTERMINAL
suspension polyvinylchloride - 悬浮聚氯乙烯 (0) 投诉
P:2009-10-22 14:05:37
Steward 28R0480-100 Ferrite core 磁铁芯/
Steward 28R1103-020 Ferrite core 磁铁芯/
Steward 28A0434-0A2 Ferrite core 磁铁芯/
Ferrite Core C5A RH 6.8*4.2*14.2 磁铁芯/
Steward 28A2024-0A0 磁铁芯/
FERRITE F5 RH 26X28.5X13MM 磁铁芯/
FERRITE K5ARH 12x5.6x20MM 磁铁芯/
FERRITE CORE RH14.27x28.5x6.35MM 磁铁芯/
Ferrite  F18A RH27x28.4x17.8x8mm 磁铁芯/
Ferrite 10.0X7.0X10.0mm 磁铁芯/
Fair-Rite 2643665702 磁铁芯/
Steward 28B0375-300 磁铁芯/
Steward 28B1225-100 磁铁芯/
spectrum-sliced - 限幅谱 (0) 投诉
P:2009-10-22 14:11:39
Manufacturerpart number Material Description
Molex15049209100 KK Polarizing Key Polyester
Molex190190012.250X.032 FEMALE QD AVIKRIMP (AA-8140)
Molex190700015RING INSULKRIMP (AA-221-10X)
Molex19092031CONN PLUG  .093  3 CIR W          19913P
Molex22267061KK 100 IDT FTh Std Tin 6ckt
Molex22426085KK 100 IDT 22awg FTo Pl Ramp Tin 8ckt
Molex39000430New Mini Fit Crimp Pin W/Plt
Molex39013149MiniFitJrPlg FreeHng /DH V-0 14Ckt
Molex390260355264-03 DYED IN YELLOW  YE      526403YE
Molex39521104QIK Flecs Female Assy Tin Plt 10Ckt
Molex3952126526CKT QF FEMALE ASSY          532026BT2
Molex39521345QF50 R/CABLE CONN ASSY 532034BT2
Molex436400200MicroFit 3.0 Plug SR Pnl Mnt 2Ckt
Molex436802002Sabre Plug WtW SR V-0 2Ckt
Molex441930003ModJack  Dual Port w/Nails  50 SAu  8/
Molex456090001SPOX BMI Recept.  16 ckt.
Molex4810304102.5mm WTB Conn Hsg 4ckt White
Molex4810602102MM WTB CONN HSG 2CKT WHITE
Molex4810604102MM WTB CONN HSG 4CKT WHITE
Molex4810611102MM WTB CONN HSG 11CKT WHITE
Molex4815106102.5MM W/B PLUG CONN HSG L/F WHITE 6CKT
Molex50133011001.0 W/B 1-Row Rec Hsg 11Ckt
Molex503750532.5MM LOW PROFILE HOUSING     526405
Molex50841125MLX PLUG 12CKT WHITE 94V0 4202112CWHT
Molex524840810MI-2 WTB S/R IDT REC 8CKT 524840810
Molex5274610700.5 FPC ZIF Hsg Assy RA 10Ckt EmbsTp Pkg
Molex541282419MFB I/O CONN.HARNESS ASS'Y
Molex545960210Mini Mi2 Rec Hsg Assy 2Ckt
Molex545960610Mini Mi2 Rec Hsg Assy 6Ckt
Molex545960710Mini Mi2 Rec Hsg Assy 7Ckt
Molex545961210Mini Mi2 Rec Hsg Assy 12Ckt
Molex545961310Mini Mi2 Rec Hsg Assy 13Ckt
Molex545961410Mini Mi2 Rec Hsg Assy 14Ckt
Molex545961610Mini Mi2 Rec Hsg Assy 16Ckt
Molex545972400Mini Mi2 Clip 24Ckt
Molex545972600Mini Mi2 Clip 26Ckt
Molex554820519Mini Mi2 1Row RelayWaferAssyW/PnlMut5Ckt
Molex554820619Mini Mi2 1Row RelayWaferAssyW/PnlMut6Ckt
Molex554820819Mini Mi2 1Row RelayWaferAssyW/PnlMut8Ckt
Molex554821219Mini Mi2 1RowRelayWaferAssyW/PnlMut12Ckt
Molex554821819Mini Mi2 1RowRelayWaferAssyW/PnlMut18Ckt
Molex555011541Stick Pkg For MZP BtB Plg Str Assy154Ckt
Molex556592019Mini Mi2 2-Row Relay Wafer Assy 20Ckt
Molex556592419Mini Mi2 2-Row Relay Wafer Assy 24Ckt
Molex556592619Mini Mi2 2-Row Relay Wafer Assy 26Ckt
Molex556592819Mini Mi2 2-Row Relay Wafer Assy 28Ckt
Molex556593019Mini Mi2 2-Row Relay Wafer Assy 30Ckt
Molex556593619Mini Mi2 2-Row Relay Wafer Assy 36Ckt
Molex556593819Mini Mi2 2-Row Relay Wafer Assy 38Ckt
Molex556594019Mini Mi2 2-Row Relay Wafer Assy 40Ckt
Molex685060096POS-LOCK RECEPT  170328-1
Molex709844009LFH Male Insert Mold 40Ckt
Molex716243000SHLD CABLE KIT SUB ASSY 716243000
Molex73100020750 OHM SMB STR JCK PCB RE
dual printer - 双侧印字机 (0) 投诉
P:2009-10-22 14:12:13
Molex739310041Latch, SFP Adapter, Rev. 7
Molex744410010SFP Connector Assembly 30"SAu 20Ckt
Molex750001048TDP 48 Ckt Asy w/o Carrier Strip
Molex75115404848 CKT TDP PLUG CABLE KIT (4-40/BLK/NI)
Molex7818100031.27mm iVDR Rec Vt .38AuLF 26Ckt
Molex875682244MGrid IDT Rec W/PolKey .76AuLF 22Ckt
Molex875683044MGrid IDT Rec W/PolKey .76AuLF 30Ckt
Molex875683444MGrid IDT Rec W/PolKey .76AuLF 34Ckt
Molex8798570442mm MGrid IDT Rec /MtlLtc .38AuLF 44Ckt
Molex900750031PLUG 6/6 LOOSE 900750031
Molex901700014QF50 SRf DIN 41651 Std LoPro 14Ckt
Molex901700040QF50 SRf DIN 41651 Std LoPro 40Ckt
Molex9058413081.27mm PF LoPro IDT B-In Tube Wht 8Ckt
Molex916320008IB M CONN UPR D/C SHELL 4X 26AWG
Molex916350002LL M CONN 4X PCB W/O EQUA SUB ASSY
Molex919660002PLUG KIT 4CKT 91966-0002
Molex9801800012.8 mm Pn Hsg PBT 2Ckt
Molex985720730Airbag Ford Assy  26Ckt
Molex986312001HDX ModFram w Lev std WrEx Gry 30Ckt
Molex989891021Pin Conn Unseald Blk 5Ckt
Molex2061101062FemaleTermChainBrsTin18-241561-(P901)
Molex2062101062MaleTermChainBrsTin18-24 1560-(P901)
Molex2091102093 Female Term Chain Tin 14-20
Molex8500113KK 100 Crp Term Std 22-30 Awg Tin
Molex8520101KK 100 Crp Term Std 22-30 Awg Tin
Molex16020107SL Term Crp M Tin 22-24 Reel
Molex16021113SL Term Crp HiFrc F 30 SAu 24-30 Reel
Molex16021124SL Term Crp HiFrc F 15 SAu 22-24 Reel
Molex39000077NEW MINI FIT CRIMP TERM          5556-T3
Molex39000183MiniFit Term Crp Fem Chn Bz Au 22-28
Molex39000221MiniFit Term Crp Male C Bz Au 22-28
Molex39000282TERMINAL .093 CRIMP PIN            1189T
Molex390004432MM CONN CRIMP PIN            5294PT27F
Molex190030110.205 X .032 FIQD PINK CONT AA-2214C
Molex190240004.250 X .032 MALE QD VIBRA.TAPE (AMCT-4T)
Molex190690364RING KRIMPTITE TAPED (M-1118-08T)
Molex190700013RING INSULKRIMP (AA-221-08X)
Molex190700069RING INSULKRIMP (BB-223-06X)
Molex190710190RING BZD INSULKRIMP (E-657-14X)
Molex190850005METAL STRIP RING VIBRAKRIMP (RZ-4129-08)
Molex430300004MicroFit 3.0 F Crp Term Chn Tin 26-30
Molex737720004EVC CRIMP FERRULE              737720004
Molex940303910FEM TERM 6.3/0.8 BRS UNPL 1-2.5
Molex8650116KK 156 TERMINAL CRIMP 22-26 AWG GOLD
Molex8700048MINI K.K. CRIMP TERMINAL      5159PBT
Molex190160009.250X.032 FEM QD KRIMPTITE AA-1140 SPM
Molex190160098.187X.020 FEM.QD KRIMPTITE (M-1136)
Molex190190006.187X.020 FEMALE QD AVIKRIMP (AA-8137)
Molex190700017RING INSULKRIMP TAPED (AA-221-10XT)
Molex190730172RING AVIKRIMP TAPED (C-828-10T)
Molex350449102TERMINAL FOR 2.0/2.5 B-IN CONN.
Molex357252411.250 SLIP-ON REC
Molex357360332RBV 1.25-4 RED
Molex430310004MicroFit 3.0 M Crp Term Chn Tin 26-30
Molex431782001Sabre Term WtW M Unplated 14-18
Molex4815000012.5MM W/B PLUG CONN TERM (CONVENTIONAL)
Molex5005882001.25 WtB Crimp Rec Term Chn 28-32
Molex675450000USB series Mini-B plug shield case
Molex675460000USB series Mini-B Plug cover shield
Molex739310101SFP-Cable Plug w/6.1mm hole - Top Half
Molex739310111SFP-Cable Plug w/6.1mm hole - Btm Half
Molex745470035Upper Backshell - x4 CX4, 24awg, key 2,7
Molex745470075Upper Backshell - x4 sata, 28awg, key 7
Molex745790010LIGHT PIPE XB IPASS
Molex747560201QSFP 26 AWG Bottom Shell (Cast)
Molex9153700044X upper die cast shell 24 AWG
Molex9153700054X upper die cast shell 26 AWG
Molex9153800044X lower die cast shell 24 AWG
SZ type cable - SZ型电缆 (0) 投诉
P:2010-04-10 10:47:39
少量现货: 54150-0878
生产厂家:Molex  ( 绝对原装正货)
Product Description:
0.50mm (.020") Pitch
SlimStack™ Receptacle
Surface Mount, Dual Row,
Vertical, 2.50mm (.098") Stacking Height,
 with Solder Tabs,
80 Circuits,
 Lead-free
loadmake/break operation - 负荷通断操作,负荷通断控制 (0) 投诉
P:2010-04-10 10:51:58
联系人:Tom
手机:13694281129
邮箱:sftang@139.com
visible light - 可见光 (0) 投诉
