首页 > 国外线缆
[问题求助] UL3135 22AWG 硅胶线抽样燃烧试验FT1不通过。
P:2009-10-19 11:27:42
UL3135  22AWG 硅胶线 UL抽样燃烧试验FT1不通过。
重新送样了还是不通过。UL要求写改善措施,怎么办啊?
哪位高手指点下,谢谢!
[wh2003417 在 2009-10-19 11:35:31 编辑过]
[wh2003417 在 2009-10-19 15:04:58 编辑过]
TE - terminal equipment终端设备 (0) 投诉
P:2009-10-19 15:09:22
材料是主要问题
litz wire - 束线,束绞线,编织线 (0) 投诉
P:2009-10-20 09:10:15
换了几次材料了,最后这次还是用阻燃胶生产的。
可还是没通过。
哪位知道的啊,帮帮忙!
cable drum table - 电缆盘转台,转盘 (0) 投诉
P:2009-10-22 11:10:04
原因如下:1.阻燃胶燃烧等级不够.2.样品线的结构不对(产生的原因有可能是产品绝缘厚度太薄)如有不明白可与我联系.手机15918695706韩小姐
fusion mass-splice - 熔融整体接头(光纤的) (0) 投诉
P:2009-10-23 12:34:56
材料阻燃等级不够,哪位知道在哪有卖更好的硅橡胶材料?
急死了!
dam - 堵水层,挡水层,防潮层 (0) 投诉
P:2009-10-23 13:26:43
LZ,干脆找人代做样算拉
schedule - 表格 (0) 投诉
P:2009-11-12 18:21:17
,  線經多大???     最好做大點。。。
UNDERWRITERS LABORATORIES, INC.                      APPLIANCE WIRING MATERIAL
Subj. 758              Section 3           Page 3135          Issued:  12-19-60
                                                            Revised:  10-16-79
Style 3135          Silicone Rubber-Insulated Wire.
_______________________________________________________________________________________________
Rating              200°C, 600 Volts.
*Conductor          No. 26-12 AWG solid or stranded of nickel or copper.  All
                    copper shall be tin, nickel or silver coated.  If tinned
                    copper strands are used they shall be 0.0152 inches in
                    diameter or larger, page 26.
*Insulation         Silicone Rubber, Class 22, 30 mils minimum Average,
                    27 mils minimum at any point.
Covering            None
Standard            Flexible Cord and Fixture Wire
Instructions        Same as for Type SF-2 fixture wire but omit Insulation
to UL                  Resistance Test and vertical flame test.
Representative      Spark Test, Page 30.
                    Flame Test, Page 31.
UL Counter-Check    (4) Same as for Type SF-2 fixture wire; aging shall be
Program                 conducted annually, omit vertical flame test.
                    (4) Flame Test, Page 31.
Marking             General, Page 13.
                    Temperature marker required, Pages 19, 20.
                    Items 7a, 7b, 7i, 9k.
Use                 Internal Wiring of Appliances where totally enclosed.
PVC - heat-resisting polyvinyl chloride耐热聚氯乙烯 (0) 投诉
