首页 > 国外线缆
[问题求助] UL1015 可以做成两并线吗?急
P:2009-10-26 19:33:24
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 1015 Issued: 1959-05-01
Revised: 2003-02-17
Style 1015 PVC Insulated Wire.
______________________________________________________________________________
Rating 80°C, 90°C or 105°C; 600 V ac, 750 V dc.
Conductor 30 AWG - 2000 kcmil.
Insulation PVC
Min. Avg. Min at Any Point
Size Mils Mils
30-9 30 27
8,7 45 40
6-2 60 54
1-4/0 80 72
250-500 kcmil 95 86
550-1000 kcmil 110 99
1100-2000 kcmil 125 112
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, unaged, Class 43.
Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties, Class 43.
Program (4) Heat Shock.
(4) Cold Bend.
(4) Deformation.
* (12) Horizontal Flame Test.
Marking General.
Use Internal Wiring of Appliances; or Internal Wiring of
Appliances where exposed to oil at a temperature not exceeding 60 deg. C or 80 deg. C (whichever is applicable). Tags may also indicate the following: 2,500 V peak - for electronic use only.
UV curable resin coated fiber - 紫外固化树脂涂覆光纤 (0) 投诉
33
