首页 > 国外线缆
[问题求助] 请问有谁知道有UL1065 28#线型吗?
P:2009-10-07 15:13:32
multi-slot core optical cable - 多槽芯电缆,多槽纤芯电缆 (0) 投诉
P:2009-10-07 22:20:33
UNDERWRITERS LABORATORIES, INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 1065 Issued: May 1, 1959
Revised: October 24, 2000
Style 1065 Nominal 1/32-Inch Thermoplastic (PVC) - Insulated
Wire for Phonograph and Volume Control Use.
______________________________________________________________________________
Rating 60°C, 600 Volts.
Conductor No. 26-16 AWG. consisting of No. AWG. copper
* stranding, tinned or bare.
Insulation Nominal 1/32-Inch wall Thermoplastic (PVC).
*Shielding Optional.
Covering Lacquered cotton, rayon or glass over conductor
Over Shielding shield.
Jacket Over the shielding a nominal 1/32-Inch Thermoplastic
(PVC) Jacket shall be applied.
*Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Tensile Strength and Elongation of Insulation and
*Representative Jacket, same as for Class 43.
* Spark Test, 3000 Volts.
UL (4) Detailed Examination.
Counter-Check (4) Insulation and Jacket, Class 43.
*Program (4) Heat Shock.
* (4) Deformation.
* (4) Cold Bend.
* (4) Horizontal Flame Test.
*Marking General.
Use Phonograph and Volume Control Use.
defoaming agent - 消泡剂 (0) 投诉
P:2009-10-08 10:58:38
,28??
optical instrument - 光学仪器 (0) 投诉
