首页 > 国外线缆
[问题求助] 问一下关于《UL1007--22AWG》线材的问题,谢谢
P:2009-10-06 16:46:33
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 1 Page 1007 Issued: 1959-05-01
Revised: 2002-12-05
Style 1007 Polyvinyl Chloride Insulated Wire.
______________________________________________________________________________
Rating 80°C, 300 V.
Conductor 32-16 AWG, solid or stranded.
Insulation Polyvinyl Chloride, 15 mils minimum average,
13 mils minimum at any point, 60 or 80°C in oil,
if applicable.
Standard Appliance Wiring Material UL 758.
Instructions Detailed Examination.
to UL Physical Properties, Unaged.
Representative Spark Test.
UL (4) Detailed Examination.
Counter-Check (4) Physical Properties.
Program (4) Heat Shock.
(4) Cold Bend
* (4) Deformation.
* (12) Horizontal Flame Test.
Marking General.
Use Internal wiring of appliances; or where exposed to oil
at a temperature not exceeding 60°C or 80°C, whichever
is applicable. Tags may indicate the following:
600 V Peak - For Electronic Use Only.
indoor antenna - 室内天线 (0) 投诉
