首页 > 专业英语|国际贸易
[翻译求助] 在收放线架上,这些是什么意思?
P:2009-10-03 20:10:15
1. Diameter of pay-off reel---- 1250 mm.
2. Pay-off of active action; el. drive of reversive action.
3. Availability of the compensator of control with electric drive of pay-off.
4. Line speed---to150 m/min.
5. Weight of pay-off reel –1500 kg.
6. Availability of the mechanism of raising and lowering drum.
7. Diameter of cable—3,0---15,0 mm.
              Take-up
1. Diameter of take-up reel –1250 mm.
2. Line speed – to 150 m/min.
3. Drive of rotation of the drum of the direct current with control from the mechanical compensator.
4. Diameter of cable ---3,0—15,0 mm.
5. Availability of the mechanism of the cable grooming
6. Weight of take-up reel –1500 kg.
7. Availability of the mechanism of raising and lowering drum
红体字的
form - 形式,形状;成形;方式;模板 (0) 投诉
P:2009-12-29 13:13:03
2. Pay-off of active action; 顺时针放线方式 el. drive of reversive action. 反方向驱动
3. Availability of the compensator of control with electric drive of pay-off.电气驱动放线控制的补偿的有效性
3. Drive of rotation of the drum of the direct current with control from the mechanical compensator.来自于机械补偿的直流电控制趋势盘具反转。
rats 奖励 20 金币,.05 声望,于 2010-1-14 14:22:05 原因:积极应助!
pulse cable - 脉冲电缆 (0) 投诉
P:2009-12-31 11:02:48
这是一份设备采购技术要求,所以对部分内容的翻译需要做一些调整:
放线方式 :电气反向驱动方式
    放线控制:电气驱动补偿
   盘具旋转驱动:机械补偿的直流控制。
rats 奖励 20 金币,.1 声望,于 2010-1-14 14:21:36 原因:积极应助!谢谢!
tunnel type cleaning plant - 隧道式清洗设备 (0) 投诉
P:2010-01-05 10:13:43
Jimmy313:
              Take-up
红体字的
你用的是什么收放线架,国外的货,还有英文?
multi-station de-reeling device - 多盘放线装置 (0) 投诉
