首页 > 国外线缆
[问题求助] 求ul 20280 安规资料
P:2009-09-23 19:10:27
UNDERWRITERS LABORATORIES INC. APPLIANCE WIRING MATERIAL
Subj. 758 Section 2 Page 20280 Issued: 1983-10-13
Revised: 2003-03-31
Style 20280 | Polyurethane jacketed cord straight or coiled in the form of a helix. |
Rating | 80°C, 300 V. |
Conductor | 2-50 individual conductors, Nos. 36 through 16 AWG, different conductor sizes may be used in one cord. |
Insulated Singles | Labeled or complies with manufacturer's AWM Procedure. |
Assembly | Two to eight conductors may be laid parallel or twisted together. Nine or more conductors shall be twisted together. lay of insulated conductors not specified, but with a twist opposite in direction to the direction in which the helical cord in wound. Cable may be either straight or coiled or in the form of a helix. |
Shielding | Optional. |
Jacket | Polyurethane. Thickness of Jacket Dia of Cable Min Average Min Thickness under Jacket Thickness at any point in inches in mils in mils 0.425 or less 30 24 0.426 - 0.700 45 36 0.701 - 1.500 60 48 |
Standard | Appliance Wiring Material UL 758. |
Instructions to UL Representative | Detailed Examination. Physical Properties of Jacket. Spark Test. |
(Continued on Page 20280A)
Subj. 758 Section 2 Page 20280A Issued: 1983-10-13
Revised: 2003-03-31
UL Counter-Check Program * | (4) Detailed Examination. (4) Physical Properties of Jacket. (4) Heat Shock. (4) Deformation. (4) Cold Bend. (12) Cable Flame Test. |
Marking | General. |
Use | Internal wiring or external interconnection of appliances or electronic equipment. |
de-reeling flyer frame - 越端放线架 (0) 投诉
