首页 > 国外线缆
[问题求助] UL线缆标签的使用区别
P:2009-08-17 16:28:22
FORM 1-N
FORM N
FORM 1-T
FORM T
四种标签使用的区别是怎样的? 要如何计算part? 是以部件个数计算还是部件种类计算?
power transmission - 输电,电力传输 (0) 投诉
P:2009-08-17 20:01:10
WIRING HARNESSES RECOGNITION MARKS
电线接插件认可标签
Form 1-N -- This Recognition Mark is used for harnesses consisting offour parts or less. Each piece of wire, fitting, splice, terminal block, wiring device,etc. is considered to be a part. Simple terminations of the eyelet, ring, openspade or quick-connect types are not counted as a part when determining theform label to be used. One of the four (or less) parts may be a Listed powersupply cord.
形式 1-N - 这种认可标签用于包含了四个或少于四个部件的接插件,每一电线,装配附件,接头,接线盒,连线设备等都看作是一个部件. 简单的端子比如针眼型,环型, 开口铲型或快接型端子, 在决定标签的形式时,都不作为一个部件计算在内. 这四个(或少于四个) 的部件之一可能是列名的电源线.
Form N -- This Recognition Mark is used for harnesses having morethan four parts as described above. The harness may include as one of the partsa Listed power supply cord.
形式 N - 这种认可标签用于包含多于上述的四个部件的接插件.这种接插件可能包括列名电源线作为其中的一个部件.
Form 1-T -- This Recognition Mark is used for harnesses consisting offour parts (or less) as described above, using as one of the parts, a power supplycord which has not been previously Listed and, therefore, must be subjected tothe tests prescribed for a power supply cord.
形式 1-T - 这种认可标签用于包含上述四个(或少于四个)部件的接插件, 使用未经列名的电源线作为其中一个部件, 因此必须首先经过电源线的测试.
Form T -- This Recognition Mark is used for harnesses having morethan four parts as described above and having as one of the parts a powersupply cord which has not been previously Listed and must, therefore, besubjected to the tests prescribed for a power supply cord.
形式 T - 这种认可标签用于包含多于上述的四个部件的接插件, 并且使用未经列名的电源线作为其中一个部件, 因此必须首先经过电源线的测试.
芝麻开门了 奖励 5 金币,.05 声望,于 2009-8-18 10:26:58 原因:描述的很全面详细
multipass cooling trough - 多道冷却槽 (0) 投诉
P:2009-08-18 00:15:07
路过,,学习 了,谢谢楼主的分享!
autobar - 棒材自动供送装置 (0) 投诉
P:2010-06-02 14:44:42
从哪个标准可以找到这个解释?个人想仔细研读研读!
Telecommunications - 电信 (0) 投诉
